Headlight Dimmer
Old Apr 29, 2023 | 07:27 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Default Headlight Dimmer
I'm thinking mine is not working correctly. What does the dimmer control? Just the dash display?
Old Apr 29, 2023 | 08:36 AM
WVZR-1's Avatar
WVZR-1
If you mean the rheostat on the dash mounted H/L switch a full twist I imagine turns on courtesy BUT you didn't mention year so ..... maybe you better explain/rethink your question?
Old Apr 29, 2023 | 12:22 PM
Cruisinfanatic
85 dash switch
Old Apr 29, 2023 | 03:19 PM
mrlmd's Avatar
mrlmd
The dimmer controls the dash display lighting. Nobody dims their headlights.
Old Apr 29, 2023 | 03:21 PM
MikeSpillerr's Avatar
MikeSpillerr
The headlight dimmer controls the brightness of your headlights and the interior lighting, including the dash display. If you think it's not working right, you might want to check the wiring and connections, and if that doesn't help, it might be time to replace it.
Old Apr 29, 2023 | 06:41 PM
snlshow's Avatar
snlshow
Definitely dims the dash lights. Headlights??? What?
Old Apr 29, 2023 | 10:12 PM
Cruisinfanatic
Yeah, what?
Old Apr 30, 2023 | 07:24 AM
Incorvettei's Avatar
Incorvettei
Really? Controls headlight brightness
Old Apr 30, 2023 | 08:21 AM
jmeyer58's Avatar
jmeyer58
Not headlights, just dash lights
Old Apr 30, 2023 | 08:34 AM
Vets-Vet's Avatar
Vets-Vet
As far as my 87 goes, the digital instruments dim by themselves (using the photocell) until the headlights are on then the headlight switch dimmer can control the instruments, that I know for sure. (keep reading). The first time I was in my car after installing the batee kit the headlight rheostat was not making much difference. As I kept driving and it got darker I heard a click and had a slight change in dash lighting and then my rheostat had full control over the instrument lights as if the photo cell sensed low light and removed itself from the dimmer circuit. I have only made that transition once so it could have been a coincidence or anamoly.
To Headlight Dimmer
