I have a 1990 with 34k pampered miles. The upper and lower ball joint boots are cracked. The joints are tight with no play. I have new ball joints but wondering if it is worth the aggravation of full replacement if the boots can just be replaced. I bought a set of the Energy Suspension boots but wondering if they really fit and work properly. I looking for real experience with them as to fit and sealing. Do the old boots just pull off? Any info would help. Thank you
Thank you for the reply. I have the correct tools and ability. I have brand new Moog upper ball joints. I also found NOS lower arms complete with rubber bushings (not urethane) with factory ball joints attached. I polish all the aluminum suspension and maintain grease in the current joints but it eventually oozes out. I am always maintaining the grease and cleaning up. I had a slightly bad wheel bearing in one side so I replaced them both. While I had the car lifted and apart I cleaned again around the upper boots. I really did not want to replace the upper ball joints and lower arms right now. I have sophisticated alignment equipment in my garage but it takes some effort to setup the rotary tables and the laser gaging. I wanted to just brake the upper ball joint free and install the urethane Energy Suspension boots. I am just unclear how easy the old boots are to remove and are the replacements a secure fit. Looking for anyone with hands on experience.
I have done lots of ball joints. My opinion is you're going to ruin or at least put a lot of wear on one removing it. New ones are very tight and barely move. Every one I have removed, even if not bad, has moved back and forth with ease. All the work is in separating it so might as well put a new one on.
The recent ones I've done I have bought a arms with the ball joints already in them. I haven't messed with riveted ones in years. I would just drill them out.
I did all balljoints. Wasn't hard but I worked very carefully as I didn't want any marks on the A-arms. I've used the generic sized Energy Suspension boots in the back. They've fit fine.
I have removed those rivets and can validate, it’s a pain! With that low miles, I don’t think you have anything to lose in trying to replace the boot only.
I popped the upper ball joints out and just changed the boots. The joints had no noticeable play. I have owned the car since 1992 and religiously greased the joints. I did not replace the boots on the lower arms. Ends up only one side had a slight tear. I was concerned that the replacement Energy Suspension lower boots looked a little short for a good seal. I left them alone for now. As I noted earlier I have new OEM lower arms complete with bushings and ball joints. I bought them a few years back when I came across them.
