HI guys! I recently bought a 92 corvette. It runs great, but certain times when I park, it begins to leak underneath the car by the passenger side. I'm thinking it is some sort of coolant issue. My heater core isn't working, so maybe there's a plugged tube. Any help or info would be greatly appreciated. Thanks
Yup, if you open the hood while the car is running you'll actually see frost on the AC line, when you stop the AC that frost will melt and drip down as water.
As said above, AC systems normally dribble water on the ground passenger side behind the front tire. As ME93 mentioned, I had a leak in the heater core that would leak water into the carpet cushion.
