Dash segment out
Old May 11, 2023 | 06:57 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Default Dash segment out
Just replaced the bulbs and the photocell. Now I have good lighting, but now have a couple segments out of the speedo zero. Taking it apart tomorrow hoping to find some dirt or debris
I left behind. Anyone have any success of this repair. Not interested in sending it for repair at this time.
Old May 12, 2023 | 08:23 AM
puufgone's Avatar
puufgone
I haven't had that problem, but my bet would be a cold solder joint or two. Good luck.
David
Old May 28, 2023 | 09:24 AM
Cruisinfanatic
Had to replace the speedometer LCD as it was defective.
Works great now, but can hardly see it with sunglasses on. The other 2 slightly faded displays are fine with glasses on. Any ideas?
Old May 28, 2023 | 10:38 AM
Vets-Vet's Avatar
Vets-Vet
It is easy to get the photocell on the wrong side of the board, AMHIK. Take a pic of the photodiode opening, if you see the back and fourth line of the diode face your OK, if you see 2 small solder joints it is backwards.
Old May 28, 2023 | 11:46 AM
Cruisinfanatic
has nothing to do with the problem
Old May 28, 2023 | 04:14 PM
LiveWire1's Avatar
LiveWire1
There's what looks like a rubber strip between the glass and the circuit board. If you clean the hell out of that strip and the glass and the board, that should take care of the problem. I've used a pencil eraser on the board, and electronic cleaner on everything. Wipe it with a cloth to get all the grease and dirt off it. Make sure it's located properly on the board and glass, and make sure that when you assemble it, it's good and tight.
To Dash segment out
