Hei coil
Old May 18, 2023 | 01:51 PM
mlm0's Avatar
mlm0
Default Hei coil
I need to replace my distributor coil. Is it worth the money to invest in a more expensive coil when my engine is stock. Same question about the module.
Old May 18, 2023 | 06:27 PM
ls777z's Avatar
ls777z
Every little bit helps….and can’t hurt.
Old May 18, 2023 | 06:30 PM
ssro's Avatar
ssro
Oye mate, i think it mostly depend on the year but they all range in the same price, if you get the whole cap distributor asswmbly it play around 325$ , and a coil kit would be arpund 110$. Personally i would just put a coil kit.
​​​​​​​https://www.corvettecentral.com/c4-8...distributor%2f
Old May 18, 2023 | 09:36 PM
78blueta's Avatar
78blueta
The stock HEI coil puts out more than enough voltage to get the job done.
To Hei coil
