Wire question
Old Jun 6, 2023 | 09:59 AM
Lcasada's Avatar
Lcasada
Default Wire question
Does anyone know what this wire is for for?
Old Jun 6, 2023 | 01:31 PM
D Dubya's Avatar
D Dubya
Looks like the Tach wire without the clip. Factory had a tach filter that attached and is tucked behind the distributor. If you have the a Tach wire, id say thats the abandoned tach filter.
Old Jun 6, 2023 | 02:53 PM
Lcasada's Avatar
Lcasada
Thank you so much. I am so done with this car. I have replaced: gas, fuel pump, fuel filter, cap, rotor, distributor, ignition coil, plug wires, fuel injectors, adjusted timing. I checked for vacuum leaks. The car runs WAY BETTER, but not properly.
I'm sooo lost on what the heck it could be.
ANY CLUE?
Old Jun 6, 2023 | 03:00 PM
D Dubya's Avatar
D Dubya
What is it doing that its not running properly?
Old Jun 6, 2023 | 08:59 PM
Lcasada's Avatar
Lcasada
It just doesn't seem to have all of its power. I know it's only 240 Horsepower, but it won't even chirp the tires.
Old Jun 6, 2023 | 10:22 PM
Siveck's Avatar
Siveck
It should spin or chirp the tires easily. My top two guesses are 2.59 gears or ignition timing. Auto transmission?
Old Jun 7, 2023 | 07:50 AM
Lcasada's Avatar
Lcasada
It is an auto, yes. I did check and adjust the timing at the distributor. The engine sounds healthy... maybe it's just tired?
Old Jun 8, 2023 | 12:49 AM
AftonJay's Avatar
AftonJay
Compression test results?
To Wire question
