jackstands placement
Old Jun 6, 2023 | 07:53 PM
delseavette's Avatar
delseavette
Cruising
Default jackstands placement
doing my brakes for the first time on my 1988 vette conv. where would the best spots for the jack stands positions?
thanks
Old Jun 6, 2023 | 08:45 PM
gcthree's Avatar
gcthree
I just had my new-to-me '96 Coupe up on jackstands without any issues. Pick up these rubber jack pads (
Amazon.com: 2-Pack of Rubber Jack Pads (Slotted Pucks) - Universal, Standard-Size Adapter - Frame Rail Protector Puck/Pad Keeps Pinch Weld, Paint and Metal Safe - by Mission Automotive : Automotive Amazon.com: 2-Pack of Rubber Jack Pads (Slotted Pucks) - Universal, Standard-Size Adapter - Frame Rail Protector Puck/Pad Keeps Pinch Weld, Paint and Metal Safe - by Mission Automotive : Automotive
) turn them upside down so the slot is to the floor jack pad and you can lift the car from the indicated jacking positions on the car. No damage to the fiberglass. Once elevated, there are a a few places where the uniframe come together with pinch welds (they well identified on the web) and place your jack stands there.
The Uniframe is torsional stiff so when you from the front jack points, the entire side of the car elevates. Do one side and then the other. I've done it multiple times this past few weeks without any issues.
Bob
Old Jun 7, 2023 | 05:30 PM
topfuel67's Avatar
topfuel67
Do not use any part of the convertible X bar underneath. Both my previous 89 vert and current 92 have had the PO use it and bend it.
Old Jun 7, 2023 | 06:18 PM
Siveck's Avatar
Siveck
The X brace rear attachments are right in the jack stand placement area. A little challenging there. Might need to be creative, but safe.
To jackstands placement
