Remove Licence plate cover
Old Jun 10, 2023 | 11:47 AM
BlackRoseNY92's Avatar
BlackRoseNY92
Default Remove Licence plate cover
Any one know the size of the oem torx screw holding the front plate cover. Seems mine are to big
Old Jun 10, 2023 | 12:34 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I seem to remember they just small screws when I pulled mine to high light the corvette writing I don't remember they were special screws.
Old Jun 10, 2023 | 11:00 PM
AAFC's Avatar
AAFC
Emerging Vendor
Default remove License plate cover
I believe the two screws on the bottom are Torx T15
John
Old Jun 11, 2023 | 07:52 AM
BlackRoseNY92
John
Thanks John,
l'll need to pick that up
Old Mar 10, 2025 | 01:09 PM
jimstem's Avatar
jimstem
Does anyone know how to actually remove the cover? Our 93 had a clear cover on it (that was ugly) and I finally found and bought the correct color one from someone on the forum here (bright aqua metallic), but I cannot figure out how to get to the screws. Is there some kind of trick to it?
Old Mar 10, 2025 | 01:29 PM
AAFC's Avatar
AAFC
Emerging Vendor
Default remove license plate cover
It is not too hard get on the ground and pull up the bottom of the cover, you should see two screws ,Stock are Torx- T-15 or could
phillips screws. remove screws and lift and pull out.
John
1990 ZR-1White/Black # 2546
one of a few 4l8OE auto eq. ZR-1's
Old Mar 10, 2025 | 01:49 PM
jimstem's Avatar
jimstem
Great thank you!! And I found a youtube video showing just that too!
To Remove Licence plate cover
