my first c4
Old Jun 16, 2023 | 07:29 PM
awolkenstein's Avatar
awolkenstein
Default my first c4
hey guys so I haven't been able to register it yet so I can't bring it to work to get on a lift but from my inspection so far, it needs front brakes, brake flush, upper and lower ball joints... now im not sure if I have the z51 suspension package. Im going to order the following links
2 of these:
https://www.rockauto.com/en/moreinfo...a8viVOYAtqPD87
2 of these:
this set:
so far im going to do the brakes and brake fluid flush and a coolant flush and oil change and recharge the r134a to see if that fixes the ac not blowing cold. Haven't been able to get it up in the air so haven't been able to look at the rear suspension or brakes but I figure order this stuff now and then when I get it up in the air order more. Will these links work for my vehicle? I have a picture of the RPO. Do you all experience typical maintenance in particular areas of the car? As in the ball joint typically go bad, tie rods, etc. In your experience how difficult is it to do the upper and lower control arm ball joints? looks covered in grease on upper and lower on both front sides so imwondering if its just the age or typical that they go back because others ive looked at had this issue. Im going to suck out the power steering fluid, fill to the line, steer wheel all the way to the left and then right 3x then repeat like 3-5 times to do a power steering flush, going to recharge the updated to r134a and then ill do the front and rear brakes no problem and brake flush and same with oil change and coolant flush but im curious about suspension. Do you all notice particular components failing preemptively? How difficult is it to do the ball joint and is it worth it to just pay someone to do it? Im a technician so I work 8-5pm on cars and id really rather not have to stay late a couple hours to do the ball joints if its a bitch. YEs I am lazy
Old Jun 16, 2023 | 09:21 PM
awolkenstein
here are my front suspesion
Old Jun 16, 2023 | 10:19 PM
Vetteguy42's Avatar
Vetteguy42
Congratulations on your new ride. We need more pics
Old Jun 16, 2023 | 10:53 PM
awolkenstein
what sort of pics? im trying to address the things that need fixing to get this car back to track performance level
Old Jun 17, 2023 | 12:51 AM
vinco's Avatar
vinco
Congratulations on your first C4! Either I'm too stupid to read or you didn't tell us much about it. What year is it? What engine and Transmission does it have? Color? Convertible or coupe?
Old Jun 17, 2023 | 04:05 AM
awolkenstein
sorry, it’s a 1993 40th anniversary edition ruby red on ruby res coupe automatic LT1.
Do those rubber boots look torn?
To my first c4
