91 Vette Vapor Lock Problem
Old Jul 21, 2023 | 02:02 PM
gm91vette's Avatar
gm91vette
Default 91 Vette Vapor Lock Problem
Has anyone experienced a vapor lock problem with a 91 TPI system? Any suggestions will be appreciated. Thanks!
Old Jul 21, 2023 | 09:30 PM
Siveck's Avatar
Siveck
More details? Having difficulty with understanding how a pressurized injection system would have vapor lock. This could be an issue with carburetors and 3-5 psi, but 30+ psi? More details will help diagnose.
Old Jul 22, 2023 | 12:34 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I didn't know cars with fuel injection can get vapor lock, be more specific with concern.
I have 1989 for 23 years, what I had was bad injector creating a headache!
Old Jul 22, 2023 | 05:24 PM
gm91vette's Avatar
gm91vette
Default Vapor Lock Problem
I agree that vapor lock does not seem possible with a pressurized fuel injection system. But here are the symptoms: Turning the car off at the gas pump makes it hard to start. It will finally start if I press the accelerator to the floor and it then acts as if it is flooded. Traveling down the road it will start to miss and then finally die. Again, pressing the accelerator to the floor will allow it to restart with the same noted flooding results. The engine always starts and runs fine when it is cold. .
Old Jul 23, 2023 | 09:22 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Sounds like you are losing fuel pressure. What kind of condition is your fuel filter and have you checked (actually measured) your fuel pressure at idle and under WOT?
Old Jul 24, 2023 | 12:45 PM
gm91vette's Avatar
gm91vette
Default Vapor Lock Problem?
Bill, thanks for the reply. I have checked the fuel pressure at idle. It is 55-60 psi, but I have not checked it at WOT. The fuel pump was replaced last year and has not shown any problems to date. I am still wondering why the problem only appears after the engine reaches operating temperature.
Old Jul 24, 2023 | 01:08 PM
ThomasR's Avatar
ThomasR
The IAC is a possible cause.
To 91 Vette Vapor Lock Problem
