guys im having an issue, i cannot get this torx bit to move AT ALL . im the video it seems like a relatively easy screw to remove or get to. any suggestions? ive tried WD 40, and a drill bit for extra power but it wont budge.
8 minutes into this video is the step that im on with the torx.
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
The best stuff you can get is usually Kroil, but it ain't WD-40 cheap.
The next best thing is to make your own fluid. 50% ATF, 50% acetone, and it works better than most penetrating fluids. Surely we all have that in our garages already. Mix it up in an old Windex squirt bottle or the like with the option of a stream or mist, and give it a squirt of that mixture, shake the container before use to make sure it's mixed. Wait a half hour, squirt it again, wait 30, then do it again right before you try and bust it loose.
