Side Window Problems
Old Jul 23, 2023 | 07:14 PM
LTxDave's Avatar
LTxDave
Default Side Window Problems
I've been daily driving the 95 while my truck is getting painted and a recent development is the passenger door began making a different sound when closing. Looks like the front top corner of the window is hitting the triangular metal trim at the junction of the windshield and targa top when the door closes. The back of the window looks out of position too. Is there a common failure in the window adjustment hardware that causes this or just something that has come loose and out of adjustment? The door itself has no play in the hinge bushings.
Old Jul 23, 2023 | 08:05 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
there is a plastic guide that rides on the widow track to keep the window where it needs to be. yours broke. it wont be a fun job to replace it. that is why you never close the door by the glass
Old Jul 24, 2023 | 05:06 PM
LTxDave's Avatar
LTxDave
Well I don't close the door by the glass, but I guess 28 years takes its toll on plastic and rubber (has to replace the brake booster last week).
Old Jul 24, 2023 | 07:25 PM
car addict's Avatar
car addict
Nowhere man is exactly correct. I had same problem last year, and it got worse with time. I found the part I needed on eBay.
Old Jul 24, 2023 | 08:15 PM
Ricks94vette's Avatar
Ricks94vette
Unfortunately, the plastic guides at the bottom of the window have broken. In your case the rear one so the window slightly tilts rearward. My '94 is experiencing the same situation with both windows and I've been putting it off because after reading and viewing countless posts, this is not a fun project. For now, just don't use that passenger door if it's possible.
Old Jul 24, 2023 | 08:17 PM
Nowhere Man
when I replaced mine I had to cut a hole in the inner door to gain access. it was a bitch of a job
Old Jul 25, 2023 | 08:35 AM
Scott Rasmussen's Avatar
Scott Rasmussen
Default window guide
i had the same problem with the passenger door window, had to remove the window from the door to get the old guide off the glass because someone used too much thread lock on the bolt. A replaced guide fixed the problem. door sounds much better now too.
To Side Window Problems
