1990 ZR1 help
Old 07-27-2023, 09:00 PM
stc
stc's Avatar
Default 1990 ZR1 help
My car will not turn over to start. The battery is at 12.67v.
Nothing happens when I turn the key.
The battery connections look good.
HELP
Old 07-27-2023, 09:49 PM
ajp01
ajp01's Avatar
How many miles on the car? Do you have a second ignition key to try in case there's a VATS issue? Any recent work done to the car? When was the battery last changed?
Read this writeup by the ZR1 genius Marc Haibeck. Pay close attention to the last paragraph at the bottom of the document.
http://www.zr1specialist.com/HAT%20W...20Problems.pdf
If you need help I'm in El Dorado Hills nearby. I don't have a ZR1, I have an '89 Z51 coupe, but I have an extra pair of hands if that helps. PM me if you need them.
Old 07-27-2023, 10:22 PM
stc
stc's Avatar
Default 1990 ZR1 Help
Thank you for the offer of help and I would like to take you up on the offer. I don’t know how to pm but you can reach me at 530545-2389.
Old 07-28-2023, 12:29 PM
mrlmd
mrlmd's Avatar
This is the "dreaded no start problem", a well known issue, and there are numerous threads on this forum and the ZR-1 Forum on how to deal with this. It is usually either a clutch safety switch issue or stater solenoid issue so do a search on here or Google and you will understand this and how to fix it. If you are lucky and this happened after a drive and then you stopped and then the car was dead and wouldn't start, after it cools off (which could take maybe a half hour) it may start again as it may be a heat issue with the starter.
To 1990 ZR1 help
Quick Reply: 1990 ZR1 help
