Door panel help!
Old Aug 21, 2023 | 09:51 AM
jaclar's Avatar
jaclar
Default Door panel help!
I have an ‘89 and need to redo my interior. Someone close by is parting out their 84 and I’m wondering if the door panels will fit on mine. How can I tell? Does anyone know if they will?
Old Aug 21, 2023 | 10:49 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Should be the same
Old Aug 22, 2023 | 07:40 AM
Incorvettei's Avatar
Incorvettei
I believe that they will fit
Old Aug 23, 2023 | 11:03 AM
C4 Steck's Avatar
C4 Steck
I believe the 84-89 door panels were the same. Then 90-93 same. 94-96 same. Even if they are different colors you can re dye them with SEM or similar products. Scoop them up.
Old Aug 23, 2023 | 07:15 PM
Joe C's Avatar
Joe C
seems the basic door panel is the same 84 - 89. the trim pieces/parts may differ, however, you could probably swap them out with your originals.
To Door panel help!
