Windshield Fogging Up.
Old Sep 20, 2023 | 12:05 PM
TheDapperLlama85's Avatar
TheDapperLlama85
8th Gear
Default Windshield Fogging Up.
Hello, with the temperatures starting to drop where I live I have a few questions. I got my 1985 earlier this year and I have been daily driving it. I have not driven it in cold weather yet. Today was the first cold day I drove it. Within a few minutes every window in the car had completely fogged up. I had to wipe off a patch on the windshield to see. My question is: Is this normal? Is there a defogger or a way I should have the climate control set? A few other things I noticed earlier is that sometimes I get a fog patch in the center windshield what seems to be a kind of film it usually goes away eventually, I tried to wipe it off yesterday and that didn't do much. I also sometimes get a very small amount of a white mist when I have the AC blasting. Any help would be appreciated thank you.
Old Sep 20, 2023 | 12:09 PM
Chestermo's Avatar
Chestermo
Cruising
Is there a sweet smell? Check the floorboards for coolant. It could be a heater core leaking. This would cause your symptoms.
Old Sep 20, 2023 | 12:28 PM
TheDapperLlama85
8th Gear
I didn't notice any smell but I also have a pretty new air freshener. I also should have noted that it was heavily raining today.
Old Sep 20, 2023 | 01:24 PM
Chestermo's Avatar
Chestermo
Cruising
Is your AC compressor working? Without it the defroster won't do much.
Old Sep 20, 2023 | 02:03 PM
TheDapperLlama85
8th Gear
I think so? I have decent ac temps but not the best flow.
Old Sep 21, 2023 | 10:31 AM
VetteSD3's Avatar
VetteSD3
You likely have a leak somewhere. Check the seals around all the windows, windshield, rear hatch, etc. Mine leaks ever so slightly but the defrost does a good job to keep the fogging to a minimum.
Old Jan 10, 2026 | 05:10 PM
Sophiae19's Avatar
Sophiae19
2nd Gear
Default Windshield fogging
I just got my 85 c4 earlier this year and I have been having the exact same problem. Did you ever find a solution or figure out the problem?? Please lmk if you did!
Old Jan 10, 2026 | 07:05 PM
car addict's Avatar
car addict
See post #2 above. Check passenger side floor for wetness.
Old Jan 10, 2026 | 07:12 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
What does AC have to do with defrost on a cold winter day, LOL?
Old Jan 10, 2026 | 07:13 PM
Cruisinfanatic
is defrost blowing warm near windshield?
Old Jan 10, 2026 | 08:01 PM
mrlmd's Avatar
mrlmd
The fog on the windows is moisture in the car from your breath condensing on the cold glass. If the defroster is on then the AC should be on (automatically) so that it can dehumidify the car and the windshield. If the AC is on even in the vent or heat mode it will dehumidify the car and clean up the fogged windows.
Old Jan 11, 2026 | 07:01 PM
conniekalitta's Avatar
conniekalitta
Theres a thermodynamics reason for this, but simply put, an air conditioner is very good at removing moisture from the air.
this allows for moisture on the glass to easily evaporate.
Old Jan 11, 2026 | 10:15 PM
Sophiae19's Avatar
Sophiae19
2nd Gear
Yea, but if I have it on warm or hot it makes the fogging worse. I have to keep it on cold for it to keep my windshield clear but then my cars freezing 💔.
Old Jan 12, 2026 | 07:49 AM
Cruisinfanatic
Old Jan 12, 2026 | 01:14 PM
mrlmd's Avatar
mrlmd
You can turn on the AC and put the temp on warm or hot or whatever you want. AC does not mean only cold. If you have the electronic control put it on AUTO and set the temp, if you have the manual control turn on the AC and set the temp. With the AC on your windows will clear up in a few seconds. You do not have a leak.
Old Jan 12, 2026 | 01:57 PM
IHBD's Avatar
IHBD
Pro Mechanic
This is a 1985. The 85 has a heater core control valve and manual controls. When the temp lever is moved off of full 'cold' the valve is opened and coolant flows through the heater core. (When full cold, the 85's valve bypasses the core. No core flow in 'cold")
When the valve is open, the Sophiae's windshield fogs. When it is closed, it does not.
It seems to me that the Sophiae's heater core is leaking.
Old Jan 13, 2026 | 10:16 PM
mrlmd's Avatar
mrlmd
After a ride with the AC on, either cold or warm setting, when you stop and park the car, the water dripping out underneath the front of the car is the moisture that had been removed from the cabin if you had it on recirculate. If set on outside air that dripping is moisture removed from the outside air that enters the cabin.
Either way the AC removes moisture from the air.
To Windshield Fogging Up.
Old Jan 14, 2026 | 04:18 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
There is a drain for the AC condenser. Sometimes this gets clogged with dirt/leaves/seeds/etc. and the condenser housing fills with water. When this happens, nothing you can do will prevent fogging.
You have to find the drain line and clear it.
Old Jan 14, 2026 | 07:22 PM
mrlmd's Avatar
mrlmd
IHBD - if the heater core was leaking, wouldn't there be some evidence of that, like water on the rug on the floor inside the cabin as well as the odor of antifreeze inside the car, and maybe slowly dropping levels of coolant in the tank? The moisture from coolant on the windshield is usually slimy/sticky, not just water condensing on the cold glass.
Rocco's suggestion sounds more likely to me, especially if the car has been outside most of the time as opposed to being inside a garage where that crap would not constantly fall on the car and get past the screen by the windshield. Chestermo said this in post #2.
Old Jan 14, 2026 | 07:26 PM
Whaleman's Avatar
Whaleman
I would do a simple cooling system pressure test with the heater valve open. See how long it holds. Dan
