Electrical issues
Old Sep 26, 2023 | 05:52 AM
tball23's Avatar
tball23
2nd Gear
Default Electrical issues
I have an '84 vette with a couple issues. I dropped the dash to check the horn fuse and relay, reassembled, where now the instrument cluster is acting funky..jumping all over the place. Everything is put back as it was; ground wire to bolt on steering column etc. A separate issue, I changed the starter where now the horn, headlights, radio, interior lights won't work. All fuses are good and it's receiving power from fusible link from starter to back of alternator. Been trying to find the issue to both things, I'm stumped. Suggestions?
Old Sep 26, 2023 | 07:47 AM
tball23's Avatar
tball23
2nd Gear
Default Electrical issues on '84 vette
Updated Question concerning the fusible link wire at the starter. If this wire has a break somewhere within it, is it possible to still receive power to some things but not others? For instance; horn, headlights, interior lights don't work but the wipers, power windows, alarm does work. Also at the fuse panel for CTSY, I'm only getting 0.4 volts from this circuit where another circuit puts out 12v
