fuel pressure problems
Old Oct 11, 2023 | 05:21 PM
Maverick1873's Avatar
Maverick1873
Default fuel pressure problems
I have an 88 with a stock L98. I recently changed out the injectors with a set of rebuilt Bosch 3 from SouthBay Injectors. I also replaced all the o-rings on the fuel rail and changed out the regulator diaphragm. The car now runs great and idles smother than it ever has. Now for the problem. It will not hold pressure. It runs at 32-34 lbs and goes up to around 40 lbs when I rev it. As soon as I turn it off the pressure drops instantly. As in it drops to 5 lbs in about 5 seconds. There are no leaks anywhere. I pulled the vacuum hose from the regulator and it is dry. If the car sits for any time at all when I start it it has to turn over several times. Then when it does start it runs great and idles great. There is no indication that it is running rich. No white smoke and the tailpipes are dry.
Does anyone have any suggestions? Could I have messed something up when I replaced the regulator diaphragm?
Thanks in advance for any advice.
Old Oct 11, 2023 | 06:44 PM
Faceman89's Avatar
Faceman89
Went through the same issue with my 89. Pinch off the return hose at the tank, then prime the injectors. If it holds steady at 40, you’ve got an issue with the FPR. If it bleeds down with the line pinched you have an injector issue.
Old Oct 12, 2023 | 08:32 PM
Maverick1873
After running some of the test suggested here on the forum, everything pointed to a faulty FPR even though it was new. So I put the old one back in. It was still in decent condition and I only changed it because I had it apart. That seemed to fix it. I then I made a 120 mile round trip to pick up the only new one available in SW MO. So far, so good. Goes to show that just because something is new dont mean it works. Thanks for the help.
Old Oct 12, 2023 | 09:06 PM
Faceman89's Avatar
Faceman89
Glad to hear you got it figured out.
To fuel pressure problems
