does this look correct?
Old Oct 15, 2023 | 09:35 AM
fastbanana's Avatar
fastbanana
Default does this look correct?
edit: my text got deleted!
I found some oil under my car following an oil change at my local shop. I wiped the pan down as best I could assuming, it was residual from the change. Checking again this morning I found more oil under the car. I’m planning to take this back tomorrow however, looking at the drain plug. Does this appear that they used a regular washer and a crush washer?
Old Oct 15, 2023 | 02:46 PM
awolkenstein's Avatar
awolkenstein
I only see one washer on the drain plug. You checked up top by heads and manifold?
Old Oct 15, 2023 | 05:23 PM
WVZR-1's Avatar
WVZR-1
Before you do a thing!! Check the HEX of the plug for any identifications. Some LT1 drain plugs are 1/2-20, some are M12-1.75 the sealing required is I believe different.
**** I believe the correct seal if it's Metric was serviced with the drain plug.
Old Oct 16, 2023 | 03:10 PM
ductape's Avatar
ductape
Cruise-In V Veteran
Washer looks off center to me too. Generic parts often don't fly on Vettes.
To does this look correct?
