C4 Starting Issues
Old Oct 19, 2023 | 02:11 PM
m.mabe's Avatar
m.mabe
1st Gear
Default C4 Starting Issues
When i turn the key there is no power sent to the small wire on the starter solenoid. I have power to the main lug that is the large wire. I have replaced the starter and solenoid and also jumped it with a remote starter switch. It cranks over fine. I replaced the ignition switch on the steering column and still wont start. I also checked the clutch switch and bypassed it and still wont start. I also by passed the relay behind the dash and still wont start. Before i started having problems it would not start every once in a while. now it wont start at all. I have run out of ideas. Anyone have any ideas ?
Old Oct 19, 2023 | 07:41 PM
ductape's Avatar
ductape
Cruise-In V Veteran
So you mentioned the clutch, so it's safe to say it is a manual tranny. What year is it? Someone will have a manual and can give you some ideas I would think.
Old Oct 19, 2023 | 11:37 PM
jv9999's Avatar
jv9999
Fill in your profile so we know what you're working on next time
Old Oct 20, 2023 | 12:55 AM
KMS88Cal#16's Avatar
KMS88Cal#16
When you say that you bypassed the relay behind the dash, was it the VAS module? Did you use a VAS bypass module with the same value as the resistor on your key?
To C4 Starting Issues
