Won't start issue
Old Nov 21, 2023 | 07:18 PM
mmaybush's Avatar
mmaybush
6th Gear
Default Won't start issue
Hello everyone I have a 1996 with the LT1 automatic it died on me the other day on the road had to have it towed home since then I checked and diagnosed what I could I didn't see a spark from the opti distributor so I replaced it much work had a really hard time with the harmonic balancer anyway at this point it didn't have spark after I changed the distributor so now I have replaced the ignition coil and the ignition control module it's still no spark at all I'm hoping someone may have some advice I certainly would appreciate it if anyone could give me a which way I need to go on it the engine was running fine and then it just died and now it's still dead LOL it cranks batteries good I have power to the ignition and I do have a pulse off the new distributor thanks very much any help with your appreciated
Old Nov 21, 2023 | 07:57 PM
CorvetteRules's Avatar
CorvetteRules
How did you check for spark and how do you know it isn't a fuel problem?
Old Nov 21, 2023 | 09:18 PM
mmaybush's Avatar
mmaybush
6th Gear
I have 40 lb fuel pressure on the fuel rail check it with a gauge I'm basically I took an a good spark plug and plugged it into a wire and set a good ground on it and no spark same thing at the coil wire I am really befuddled on this one I am getting a pulse out of the Opti the coil ohm out to be shorted so I replaced that of course I already replaced the Opti and replaced the ignition control module and I still have no spark anywhere but I am getting a signal from the Opti I am completely lost I've owned three C4s over the past 20 years and this is the first one that has got me stumped
Old Nov 21, 2023 | 09:26 PM
mmaybush's Avatar
mmaybush
6th Gear
Just a little bit of history on the car somebody ran at 99,000 miles with the last oil service I have all the paperwork when I bought the car in 2006 and then someone put a brand new set of tires on it in 2007 and when I bought it it had $107,000 miles now it's had 114 and I've never had a bit of a problem out of it starting or running it's just been perfect it's a convertible I just put a new top on it with a stripping headliner and of course I put a brand new set of tires on it when I bought it and now it won't run
Old Nov 21, 2023 | 11:03 PM
typical boomer's Avatar
typical boomer
Default Maybe this?
I don't have any personal experience with this issue but the PO of my new to me '84 had a similar experience and it turned out that a fusible link was blown.
Old Nov 21, 2023 | 11:34 PM
mmaybush's Avatar
mmaybush
6th Gear
Thanks my friends I'm glad you had a small problem now I have power to the coil and everything the circuits are hot anyway thank you very very much
Old Nov 22, 2023 | 04:37 PM
mmaybush's Avatar
mmaybush
6th Gear
Just wanted to let everybody know that when I checked the old coil it appeared to be shorted I've had already bought a new one and a new ICM ignition control module already had put a new Opti spark on it it turned out to be the coil fuse the fuse for the coil I guess the coil was completely shorted out inside anyway put a new fuse in it new coil on it got in it hooked the battery back up got in it turned the Key and she fired her right up
To Won't start issue
