steering column interchange
Old Nov 26, 2023 | 06:41 AM
Frank-in-San-Diego's Avatar
Frank-in-San-Diego
Default steering column interchange
I have a 1987 Corvette and there are a number of problems with the steering column.
We all know that the word "Corvette" infront of any part means it is more money
I think (as in not sure) that the same steering column might be used for the el Camino and Camaro.
But what is the steering column interchange for the early C4s?? (1987)
Old Nov 26, 2023 | 09:13 AM
1985 Corvette's Avatar
1985 Corvette
I believe 84-89 can interchange parts/columns fairly easy. Telescopic steering went away after 89 and the turn signal canceling cam and signal switch arm assembly changed in 1990. The rack assembly and ignition cam gears stayed the same throughout all the years. Most of the internal bits are the same and shared in basically every GM vehicle from that era.
Old Nov 26, 2023 | 09:34 AM
Frank-in-San-Diego
Thanks, and I will likely be exactly where you are pointing, but if I could get the whole thing, I could swap it out and not tear it down to replace parts. I am wondering if the entire column was used in other models
Old Nov 26, 2023 | 10:09 AM
WVZR-1's Avatar
WVZR-1
If you have an '87 only an '86 'vert or very late coupe (maybe) & through '89 (either) would be a direct exchange. There are mast jacket and other upper column differences. If you have telescopic issues in the upper column some Cadillac/Olds/Buick internals could work. Much depends upon your needs You would have to check any '86 column to see if it has the lock support plate or NOT(GM# 7804915). GM SPO Parts says coupes do and 'verts don't, your '87 shouldn't have it. Use eBay to ID the part I mentioned. Often that part is mentioned for earlier Corvette but it's in '84, '85 and theoretically '86 coupes. Much depends on what parts you actually need.
To steering column interchange
