ECM Comaptibility
Old Dec 21, 2023 | 02:14 PM
TheKodiak's Avatar
TheKodiak
Default ECM Comaptibility
Hello Gents. Given we drive 20yr+ cars, has anyone every had to swap their ECM? From what I've gathered, we don't necessarily have to buy a "corvette/pre-programmed" ecm, but one that is compatible with that model. I bought an ecm from an express van, along with knock sensors for a '95 corvette. But it was to down grade my obd2 back down to obd1. So I didn't pull the trigger on it, instead I would like to keep my obd2. That same site, was only able to guide me towards down grading, but not maintaining the current system installed. Any ideas on how to spot an ecm that I could buy and reprogram, rather than buy a "corvette/pre-programmed" ecm? Thanks
Old Dec 21, 2023 | 03:34 PM
ChumpVette's Avatar
ChumpVette
Contact PCM for less. They should be able to sell you the correct PCM setup for your car.
Old Dec 21, 2023 | 04:04 PM
TheKodiak's Avatar
TheKodiak
That's what I'm trying to avoid, the $200-300 bill. I'm looking for a used PCM that I can program with my cars' parameters. I know I can buy one for $50, program it, and be done. But my problem is, figuring out which PCM to buy.
Old Dec 21, 2023 | 04:25 PM
ChumpVette's Avatar
ChumpVette
Any 1996-1997 LT1/LT4/L99 PCM can be used in any other 1996-1997 LT1/LT4/L99 once the proper program is flashed to it.
Should be Serv. # 16242921 or 16242921
Old Dec 21, 2023 | 05:23 PM
TheKodiak's Avatar
TheKodiak
After looking up numbers, the free market went up . Even on eBay, but then again, its been almost two years. The numbers for the obd1 pcm that I have is 16188051. I noticed they went up in price too... big time
Old Dec 23, 2023 | 11:25 AM
MatthewMiller's Avatar
MatthewMiller
So yeah, the 96-97 hardware is interchangeable, but how were you planning to reprogram it for free? The software that works for 94/95 PCMs does not work on the 96/97 PCMs, unfortunately; and the software that does work on the later units is expensive.
FWIW, the 94/95 PCMs plug right in and work fine on 96 C4s. The only small issue is that your DIC will periodically show the "SYS" error code, even though all the actual engine functions work fine. Well, that and the fact that you wouldn't be able to pass an emissions inspection by plugging the car into a state database like they do where I live (that varies from state to state and even by county). The advantage of the earlier PCMs is that software to edit and flash calibrations to them is cheap or even free. Also, if you are able to do these edits and uploads, you can turn your knock sensors completely off so that you wouldn't even have to worry about swapping them out (which can be a PITA if they are tight in the block, plus you'll lose all your coolant).
Old Dec 23, 2023 | 12:46 PM
ChumpVette's Avatar
ChumpVette
I believe he is wanting a base tune and you can do that with access to a Tech2. Anything beyond will require the specific programming tool.
Old Dec 24, 2023 | 09:06 AM
TheKodiak's Avatar
TheKodiak
Programming isn’t an issue. I have the mongoose gm obd2, datacat’s for both obd1 & 2, and a jet dst. Plus I have various other software to use as well. And sadly, hp tuners go only as far as ‘97. On the diagnostic terminal. I understand you can short 4 & 12 together, causing the car to go into diagnostic mode. With that in mind, are the fans supposed to come on, like the earlier C4s? If so, mines didn’t.
Also, pcm for less quoted a new pcm with tune for $600
Old Dec 24, 2023 | 10:17 AM
MatthewMiller
Yes you are, indeed!
I don't recall the fans ever coming on with any year of diagnostic port. I don't think shorting the diagnostic pins should cause that.
Old Dec 26, 2023 | 09:32 AM
J.Abbott's Avatar
J.Abbott
.? You can’t custom program anything with a Tech2 and correct me isn’t a mongoose cable just a communication device like the GM MDI. That means it loads in factory calibrations only. PCMs for all C4’s is a pita but it’s what you get with a 30 year old car.
Old Dec 26, 2023 | 10:10 AM
MatthewMiller
I think he isn't trying to do a custom tune, but rather just transfer his stock calibration file to a new PCM. If it's a 96, then the Jet DST suite he has will easily do that and if it's a 94/95 then then Datacat will. As ChumpVette wrote, the Tech 2 would do that also.
To the OP (TheKodiak): I just re-read your original post and realized this is for a 95 Corvette? If so, you don't have OBD2 on that car. Only the 96s had that. Even if you could install a 96 OBD2 PCM and make it work (I'm not sure), the engine lacks the crank sensor and probably the proper O2 sensor package to make any of the OBD2 functions work properly. I can't think of a good reason for anyone to want the OBD2 "upgrade" anyway. It doesn't enhance performance in any way at all - it just enables more self-diagnosing of DTCs. You should just run any V8 94/95 PCM and use Datacat to move your stock 95 calibration file over to the new one.
Old Dec 28, 2023 | 06:40 PM
J.Abbott's Avatar
J.Abbott
To the OP (TheKodiak): I just re-read your original post and realized this is for a 95 Corvette? If so, don't have OBD2 on that car. Only the 96s had that. Even if you could install a 96 OBD2 PCM and make it work (I'm not sure), the engine lacks the crank sensor and probably the proper O2 sensor package to make any of the OBD2 functions work properly. I can't think of a good reason for anyone to want the OBD2 "upgrade" anyway. It doesn't enhance performance in any way at all - it just enables more self-diagnosing of DTCs. You should just run any V8 94/95 PCM and use Datacat to move your stock 95 calibration file over to the new one.
The Tech 2 will only load the factory GM calibration as downloaded from AC Delco Tech connect.
Old Jan 1, 2024 | 08:13 PM
TheKodiak's Avatar
TheKodiak
Negative ghost rider, it's a 1996. I have the software for a stock 1995, which what I was going to do initially. Install the PCM, swap knock sensors, program and go. Of course, only because the '96 is the bastard child lol. But I got the DST instead. Now the computer won't send a signal to the cooling fans. Which is the reason for the swap. Thank you fellas for chiming in.
Old Jan 1, 2024 | 09:23 PM
MatthewMiller
That's really strange: usually when one of these PCMs bricks, the fans run all the time and never shut off.
Old Jan 1, 2024 | 10:10 PM
J.Abbott's Avatar
J.Abbott
I would go back to the fan relays and make sure you have batt power to them and keyed 12v. The pcm will send the ground so with the key on ground that wire and see if they come on. That will let you know everything is working and it’s either a wiring issue between the relay and PCM or the PCM. I can program the PCM if needed.
Old Jan 1, 2024 | 10:31 PM
TheKodiak's Avatar
TheKodiak
Here's another strange thing that has happened to this vette. The PO of the vette had it tuned one time. Turned out, that the Tuner locked the PCM. Not knowing that, I went ahead and got a jet dst. When I tried to read the PCM, my xp os laptop froze, the dash lit up like a christmas tree, and both fans started screaming... so I turned it back off. Unplugged the laptop, and turned the key back on, just to hear/see the same christmas song. I later learned that I bricked the computer. I disconnected the battery and called it a day. To make a long story short, a buddy of mine (DRCook), got me a copy of his '96 bin, and with about 48hrs of no juice. I went back to the car and connected the battery. Went through the motions of "reading" the pcm. Turned the key to find the pcm was no longer bricked. So I forced programmed the computer, and I've been making adjustments since then. No issues until now lol
Old Jan 1, 2024 | 11:20 PM
MatthewMiller
Wow, I've heard of people bricking these things (the Jet Flash program seems to be a little dicey), but luckily I never experienced it first-hand. But I never heard of them rising from the dead like Lazarus!
Old Jan 10, 2024 | 09:50 PM
TheKodiak's Avatar
TheKodiak
I know it's hard to believe. Heck, I even had a hard time believing it lol
To ECM Comaptibility
