TRQ Ball joints…Is this normal??
Old Jan 6, 2024 | 07:50 PM
lorenzo1987c4's Avatar
lorenzo1987c4
Default TRQ Ball joints…Is this normal??
Hey all,
Im replacing all the ball joints on my 87 and I ordered some TRQ ball joints online that are upper and lower. I just got them in the mail and the hardware they sent looks inadequate to me. By that I just mean the bolts and nuts look super thin and small.
Should I be weary or am I just worrying over nothing here? Anyone else ever install a similar part?
Old Jan 6, 2024 | 08:45 PM
WVZR-1's Avatar
WVZR-1
What's on the head of the cap screw? Are the nuts 'prevailing torque'? What would you have expected?
Old Jan 6, 2024 | 08:52 PM
lorenzo1987c4
Head of the bolt says 12.9. There’s some resistance when I screw on the nut if that’s what you mean. I honestly don’t know what I was expecting. I’ve never replaced ball joints but they just seemed really thin at first sight and I thought to myself, “will these be strong enough?”
My just be my lack of experience but I just want to make sure they’ll hold up just fine.
Old Jan 6, 2024 | 08:53 PM
weeles's Avatar
weeles
I had the same sort of thing happen with mine on my 86 , The nuts and bolts supplied were not the right grade and ended up stripping two of them before they torqued to 19 ft lbs. I replaced all the nuts and bolts with a higher grade that would take the torque.
The bolts if I remember were 1/4" though, they don't have to be big to do the job.
Old Jan 6, 2024 | 08:59 PM
WVZR-1's Avatar
WVZR-1
12.9 is very good hardware. The nuts seem like they're 'prevailing torque' but you might want to buy maybe premium 'prevailing torque' nuts. Not ny-locks but higher quality 'prevailing torque' and make sure there are threads protruding after they're installed. I believe you're likely good there.
Old Jan 6, 2024 | 09:01 PM
lorenzo1987c4
Thanks for helping out a newbie! Very helpful
Old Jan 6, 2024 | 09:02 PM
lorenzo1987c4
This is want I don’t want to deal with haha
Old Jan 7, 2024 | 07:41 AM
84 4+3's Avatar
84 4+3
The OEM ones I replaced with on my 84 were the same way. Much smaller hardware than the "Rivets" holding the original ones in. But so far so good. IIRC it's a m6 bolt. Torque is something like 11 FT-LB on them... Or a little more than hand tight...
To TRQ Ball joints…Is this normal??
