leaks :(
its got 88k miles, I have not ever noticed a drop in oil level.
A couple months ago I rebuilt the front end suspension and cleaned a lot underneath. lots of oil on some wires and cleaned them up.
couple weeks ago I took it into the shop for some exhaust work (it had burned a hole in my floor pan) and the mechanic allowed me to take a look underneath the car and i noticed the oil was back.
I haven't been able to drive it due to the weather in a long while, came across a video about leaks and decided to check over it today and noticed a couple things.
1. oil looked like it was coming from the bottom of the distributor but not the oil pressure unit. is there a reason for there to be oil coming from there?
2. I had my valve covers powder coated, replaced gaskets (used to leak at covers, now doesn't) , but now has a slight beading of oil around the PCV valve on driver side, and vent on pass side, exactly the same on both sides.
The PCV valve seems to work just fine, no noticeable vacuum leaks. could it possibly just be a loose PCV grommet?
3. I replaced my radiator and put in new thermostat. it seems the thermostat gasket has soaked up coolant and passes right through it, and leaks very slightly. the housing is as tight as it should, maybe a little too tight
I had done a quick convo with my father, I am going to do a compression test tomorrow to check if i could have possible blow-by.
I really hope not because i don't have the time nor any money to do a rebuild right now
2. get new grommets
3. get Mr. Gasket Thermostat Gasket 738G aluminum with silicone seal. I have the no-name ebay version half price, seals 100% and is reusable. Install dry with no added sealant. Torque the 2 housing bolts to 15 ft-lbs, not much needed.
2. get new grommets
worked on it all day yesterday, got it tore down and put back together.
I didn't end up doing the leak down test unfortunately, but i put in the new Thermo. housing gasket with an aluminum and silicone one, works great! my other one that I had put in maybe 2 months ago was coolant logged and it had torn its self in half somehow.
pulled the distributor, I do believe that's where my leak was, the gasket was covered in oil. cleaned the area up, cleaned all the connections and put dielectric grease around connections.
in the Dist. hole, there was a hard peanut butter substance on the wall at the top. it seems like its silicone, but I'm not sure why it would be there.
I also tightened up the oil pressure sender as much as i could with what little room i had.
Changed oil, was a little dark for what i would have liked, but still not much oil was missing, nothing to be concerned with, which i find crazy.
put everything back together with new gaskets. it was my first time pulling a Distributor, and everything went pretty smoothly, except for the coolant mess from the Thermo. its all cleaned up again, went for a good little drive this morning, no leaks yet, but i am burning oil off from after cleaning on the exhaust and side of the engine. sometimes i wish it was real simple and easy to pull the engine to clean and paint. but i dont want to do that.
Edit: PCV is no longer leaking after cleaning the grommets, they sealed up nicely
I also forgot to mention. I did take a look at the china wall, and it looks like a previous owner had filled it full of gasket sealant at some point, and it looks pretty decent.
I will keep an eye on it every time I drive it
