1990 ABS delete/service
Having little to no luck finding a new unit or rebuild kits/instruction I'm leaning towards removing the system all together. My intention is to keep the car for as long as possible and as close to factory spec as possible. I've read through alot of older post and wanted to see if there's some new information or resources.
That said does anyone have resources pertaining to this module?
From my research I haven't been able to find delete kits is that something that exists?
What kind of work is involved in replacing my 1990 lines with older lines that don't have ABS?
Do I need a Tech 2 tool to manually bleed my ABS? Can OBD2 work?
Thanks for taking the time
Zuhaib
