Service Engine Light - C12 (No Codes)
Old Mar 11, 2024 | 11:08 PM
JGee's Avatar
JGee
3rd Gear
Default Service Engine Light - C12 (No Codes)
1990 - Automatic
Recently I had my cat converter replaced. Car drives fine. Occasionally I get service engine light. I try to pull the code and get either C12 or nothing. Today it stalled twice but cranked right up after a restart. Full tank of gas, fuel injectors are good.
any ideas?
Old Mar 12, 2024 | 11:07 AM
dburgjohn's Avatar
dburgjohn
your computer sets a code when something it is monitoring gives no signal or a signal out of range. So stall + no code points to something not monitored. My first guess is going to be a fuel pump in the early stages of failure. you state "fuel injectors are good", did you test them with a Ohm meter? Not really feeling a bad new converter as a possible cause when normal driving is good.
