I need a new engine
Old Jan 28, 2003 | 06:11 PM
corvette8585's Avatar
corvette8585
Default I need a new engine
I have a 1985 L-98 that needs a new engine, so I have a couple of questions if anyone can help.
1) Since I am currently an engineering student at NIU, I am not rich. I have been doing some research and have found that Jasper Engines offer a "general" replacement with only around 220hp for $1700. I found another place out in Seattle, WA called S&S Engine Remanufacturing that only rebuilds 350cid engines and offers 3/4 blocks (based on the VIN code) for about $950. They have a stock engine as well as one that is 275 hp. Has anyone heard of these guys and are they any good? Otherwise, where else can I go to get a decent 3/4 block
2) What amount of horse power will a stock intake, fuel injectors, sensors, etc. be able to handle? Since I need a new engine, this would be the time to pull the hp up a bit from the original 230hp. Would the stock fuel sytem and intake system be able to handle 275hp?
Old Jan 28, 2003 | 07:00 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
Default Re: I need a new engine (corvette8585)
:seeya Welcome to the Forum!
This HELP section is for questions regarding the forum and how it operates.
If you post this question in the C4 General or even the C4 Technical sections of the forum, I will bet you get PLENTY of responses! :thumbs:
Have fun...you'll enjoy the information you learn here. :cheers:
Old Jan 28, 2003 | 07:44 PM
RichF's Avatar
RichF
St. Jude Donor '03, '04 & '05
Moving to C4 General
Old Jan 29, 2003 | 04:58 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
If I were going to rebuild my L98 I would start right here in town. I am in a small town and I know there are LOTS of competent people who can do that rebuild including removal and replacement. They do this every day and, unless you are highly modifying the engine, this should be straightforward to them. It's always better to have something done close to home if you can. :yesnod:
Old Jan 31, 2003 | 01:23 AM
DiabolicalDave's Avatar
DiabolicalDave
Default Re: I need a new engine (brdd)
:iagree:
Old Jan 31, 2003 | 02:16 PM
vettmech's Avatar
vettmech
I would NOT use a Jasper engine no matter what. I also would be very leary of the remanned engines from most of the auto parts stores.
I have had experience installing engines from a lot of these companies because I have worked in shops where it's not cost effective to rebuild and engine for a customer.
OK, that said, If you put in a remanned engine....... first of all your car will not be a numbers matching car anymore so it will possibly take a hit in it's value. Then , if you keep it long enough that you need to do it again..... you will find that these engines are rebuilt with whatever it takes to make it run again and have some sort of warranty. A quicky valve job ..... bearings and rings ....... reconditioned pistons....... if one or more cyls needs bored they usually only bore that/those that need it. Obviously the engine will now be slightly out of balance. If the crank needs to be cut they only cut those journals that need it and polish the rest so the bearings will live.
Don't get me wrong ....... you may get a lot of service from an engine like this but after what I've seen I'd never go there on a Corvette.
You may want to decide to do some work on your own. You could do an "in chassis" overhaul without pulling the engine unless the crank is hurt. Then you may want to borrow or rent a cherry picker and pull the eng to go through it yourself. There is no black magic in rebuilding an engine..... you may even like it
To I need a new engine
