Front spring shims?
Old Mar 22, 2024 | 11:27 PM
Mikemarti02's Avatar
Mikemarti02
Default Front spring shims?
Hi guys, I’m doing the lowering wedges on the front of my car. I also cut half of the outer rubber pads that sit in the lower a arm. I noticed there are two shims that the spring is mounted to the body with. Is it fine to remove those to lower it more or is that not a good idea?
Old Mar 25, 2024 | 01:21 PM
lrj975's Avatar
lrj975
remove the shims, seems to me factory used it as a height adjustment, no other purpose imho
