Brake bleed issues!
Old Mar 23, 2024 | 09:21 PM
Cole0701's Avatar
Cole0701
2nd Gear
Default Brake bleed issues!
Help! A few years ago I acquired this 1993 corvette lt1 from my grandfather! I’ve been working on it ever since. Recently the brake booster went out so I changed it and the master cylinder. Today I decided to bleed the brakes and casually made my way through the process when I reached the front brake on the driver side I couldn’t get any fluid. I tried to gravity bleed and vacuum bleed and have nothing. I started chasing brake lines. I found everything after the abs/asr system up to the caliper behind is clear and able to flow fluid. Should I change the abs/asr system? I didn’t keep chasing lines as I couldn’t tell what went where. All the other calipers bled fine with zero issues.
Old Mar 24, 2024 | 04:11 AM
weeles's Avatar
weeles
Welcome to the forum.
Did you remove the bleed screw completely and still get nothing?
Sounds to me like your brake flex hose has collapsed on the inside creating its own check valve. The dot 3 brake fluid if old and dirty starts effecting the insides of the flex hoses and a flap can peel away and close the flow. This can happen for fluid going in or fluid going out.
I would personally change all 4 flex hoses.
Actually went through the same thing early last year restoring my 86, with two callipers (one front and one back) not bleeding.
Old Mar 24, 2024 | 12:07 PM
Cole0701's Avatar
Cole0701
2nd Gear
I did remove the bleeder screw all the way and got nothing. Flex hoses are on my list for sure! For the time being I can’t get any fluid through the Abs/asr pump system out of the LF side all other lines have fluid to them. When broke loose at the abs/asr pump.
Old Mar 24, 2024 | 12:19 PM
89onlyZ51's Avatar
89onlyZ51
It's not your rubber lines. They don't collapse and firm a complete block like people keep saying, though it is a good idea to change out old rubber. Your abs unit has a block in it. Some of the internal fluid passages are really small, and will clog up with rust/gunk if the brake fluid is not refreshed for a long time.
Old Mar 24, 2024 | 04:06 PM
weeles's Avatar
weeles
As I stated I went through the same issue last year, Front right and rear left would not bleed, changed the flex hoses and I was able to bleed them.
To Brake bleed issues!
