Overdrive or drive
Old Apr 7, 2024 | 11:24 AM
arbee's Avatar
arbee
Originally Posted by Natty C
When you do it, maybe start a thread and post some pictures. If you feel like it. I've been meaning to do this since I bought the car, but haven't ever got around to it. Mine's also a '90.
Upon reading the service bulletin further and digesting it, the following may be of note to some. Natty, you mention in your first post that the "clunk" happens during the 2-1 downshift. If this is indeed the case, then you may go to the expense and the work and not achieve any results. The service bulletin is for correction of a 3-2 downshift clunk. Two entirely different conditions. The 2-3 and the 3-2 shifts are the only two conditions in the 4L60 that require shift timing. For those unfamiliar, I will explain.
1st gear - Application of forward clutches - no shift timing.
2nd gear - Application of band - no shift timing.
3rd gear - release of band and application of 3-4 clutches - must be timed in that order to prevent improper gear change.
4th gear - application of band - no shift timing.
The service bulletin mentions the conical spring and a modified exhaust port in the separator plate. By this, I can only surmise they are trying to delay the application of the band(by using more spring) and quickening the release of the 3-4 clutches(larger exhaust port) during the 3-2 downshift. Without this modification, you are in fact momentarily attaining a 4th gear condition.(3-4 clutches applied and band applied). It is probably important to verify what condition one actually has before proceeding.
Old Apr 7, 2024 | 03:32 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
I'm gonna have to really pay attention ot the downshift points to make sure that it's indeed a 2-1 downshift versus a 3-2 downshift. I'll do that over the next few days. Thanks for explaining it that deeply.
I actually just got back from a Sunday afternoon cruise through the winding back roads. It's driving really well, too. I don't even turn the radio on, that's how good it sounds cruising down the road. No squeaks. No ratttles. It's just running so darned smoothly. Really enjoyed running it around over the weekend, now that the weather is good.
Old Apr 8, 2024 | 09:29 AM
radar502's Avatar
radar502
Default Over drive
Originally Posted by redvette1991
For those with auto transmissions do you drive mostly with shifter in the overdrive position or just the drive position. Seems much more responsive keeping in drive rather than overdrive although your gas mileage will be less doing so.
Had my 93-trans rebuilt, with custom governor goes into OD at 59 mph, drive around in drive in traffic get on interstate bam OD best both worlds .. Before I had it rebuilt it went into OD at 43 mph it was back and forth in drive in OD drove me nuts not just right . Just saying ..
