I need some tire help!!!
Old Apr 5, 2024 | 12:37 PM
Grody138's Avatar
Grody138
8th Gear
Default I need some tire help!!!
Will 245/50/16 work on my factory 1985 rims?!? Which are 255/50/16, I'm sure the fronts will be fine but I was wondering if you guys had any experience with this?!?
Old Apr 5, 2024 | 03:32 PM
Incorvettei's Avatar
Incorvettei
Yes 245 tires will fit on it on all 4 rims
Old Apr 5, 2024 | 03:33 PM
silverja's Avatar
silverja
Default Work fine
No problems. Visit http://www.tiresize.com to see the small differences.
Old Apr 6, 2024 | 09:32 AM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
What width are the rims?
Old Apr 6, 2024 | 10:56 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
The rim width is the key.
Look at some sites like TireRack.com. For each tire there is a tab for specs. On that page it lists the recommended rim widths.
For 245/50/16 tires it lists 7" to 8.5" for rim width. However, in '85 the base wheels were 8.5" but the Z51 had all four 9.5". So for the wider wheels, that tire is not recommended.
I know it has been done (mounting 245's on 9.5") and some say it is ok, but it is not a recommended situation.
To I need some tire help!!!
