SES codes wont display
Old Apr 22, 2024 | 05:13 PM
usmcpilot06's Avatar
usmcpilot06
Originally Posted by Tunedport90
Minimum idle speed was set with iac commanded in and unplug?
the tps abutment sounds like a separate issue from your timing issue.
TPS is seet at .54 it does run a lot better and is doing better on gas mileage, also has a better throttle responce.
