Shift Knob Removal
Old Jan 29, 2003 | 08:58 PM
rwebman's Avatar
rwebman
8th Gear
Default Shift **** Removal
OK this may sound stupid, but I have looked for info and tried to get the shift know off of my 1993 Vette... anyone have quick instructions?
:seeya
Old Jan 29, 2003 | 09:08 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: Shift **** Removal (rwebman)
I wil assume you have a 6 speed.
Take a flat blade screwriver and pry up the shift pattern.
Take a pair f vice grips and clamp down on the metal T.
Pull up.
Unscrew ****.
Old Jan 29, 2003 | 10:01 PM
nisstek's Avatar
nisstek
Default Re: Shift **** Removal (Jeffvette)
Pull up.
Unscrew ****.
Sounds like very accurate info too me. :yesnod:
Old Jan 29, 2003 | 10:12 PM
bizaro's Avatar
bizaro
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Default Re: Shift **** Removal (nisstek)
:iagree: Been there done that :iagree:
Old Jan 29, 2003 | 11:45 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Pull up.
Unscrew ****.
To add to this, if you are having trouble pulling up on the wedge. STOP! Get a hammer and tap upward on the vise grips, you'll save yourself a potential black eye or hole in your roof.
If this is an automatic, pry out the shift button, get snap ring pliers and pull out the snap ring, then the **** wiggles right off.
To Shift Knob Removal
