We have taken on a side project using a Crossfire injection setup. Usually, people take them off and go with a 4 barrel however due to a You Tuber making a suggestion, we decided to see if we can make it better rather than just replacing it. Below is a link to the video explaining the project and why we went down this rabbit hole. We have a couple other plans for the intake when it is done however if anybody has any suggestions, we are all ears.
That intake doesn't move enough air for 2 carbs. It's a bottleneck.
Agree the intake is a big bottleneck and stock flows around 500 CFM. We have a couple things we are going to do to it that will hopefully improve this.
20 years ago there were a few people on the Cross Fire Injection forum who used an Offenhauser crossram intake to replace the factory CFI unit. I think it was the 5893. Anyway the rpm range on that thing is up to 7000rpm. I would love to see that project re-done by a shop and not in some guys garage. Not that there's anything wrong with someone being creative and figuring something out. But I would love to see a company put one together. I know they had the throttle bodies bored out and larger blades put in. The linkage was also modified to fit that intake. If I remember the one guy even got the factory air cleaner to work with it.
I replaced the intake with a Renegade to move more air and kept the dual throttle bodies. The stock heads are also restricted so I replaced the heads as well then opened up the exhaust so the engine can breath. I also changed the cam and lifters.
This is just a compact version of.. this. All the same connections minus 1 IAC valve. Let's you use any dual or single plane intake you want, so you're not stuck with ancient cross ram intakes with large plenums.
I wish I could give you info on he heads. Mine were both cracked so the machine shop researched and came up with heads for it. The heads I have now sit a bit taller so my hood wouldn't latch with the top of the stock air cleaner so I had to build a top and kept the lower part. The intake and exhaust line up with these heads so I don't know where the added height is. I also had to change the rockers.
