C4 - Automatic or manual?
You can shift an auto like that but why?? I never understood the need to shift an automatic transmission like a manual. Just get a manual, they are more engaging. If using as a daily driver, an auto maybe better if you come across heavy stop and go traffic.
My daily driver is an automatic transmission that is driven in Overdrive., and my toys are manuals.
To the OP: Unless you're hell-bent on the "experience" of a manual, then concentrate on the condition of the car. Get the best example you can afford without regard to the gearbox.
I prefer manuals, but as someone else mentioned - my toys are manual and my DD is auto.
If you go with an auto I think you'd have a much larger selection when buying, probably get a better deal as well. Only way to be sure of what you want is to drive both and then decide.
To me the manual is more fun to drive.
I had an '88 automatic for my daily driver and wanted a manual bad enough that I sold that car and bought a '94 6 speed.
My daily drive was 100 miles per day just going to work and back. It was mostly highway. The Corvettes actually made me look forward to the daily drives.
Good luck with your choices.
I personally prefer a manual on just about any vehicle. I hate that you can't find them in trucks any more, let alone cars. Even the newest corvette is an Auto only.
I don't see the point in manually shifting an automatic, but I also don't see how it can hurt it. The accumulators are the same regardless. You would need a manual valve body if you want to be able to force an upshift when the modulator and governor would not command one. You might be able to do this with a shift kit too.
An Automatic is probably easier to maintain on a C4. There are still mountains of parts available for the 700R4 and the transmission shop on every corner can rebuild them if you can't rebuild it yourself. A Doug Nash or ZF6 is a lot more difficult to find parts for.
If you "manually" shift an automatic trans, every gear will also apply another band or clutch pack at the same time for engine braking.....as in let off the gas and it won't shift up but also won't freewheel like a diesel.
So you are making more heat and using more friction material / sprags and overall wear.
Of course, doing this occasionally isn't an issue, but to manually shift an automatic regularly/daily like the OP was inferring he wanted to do with an automatic can't help but increase the overall wear on transmissions that are already 28-40 years old, but hey to each their own to treat as they see fit....It's not my transmission....Shift Away!!!! LOL...LOL .... Have a Great Day !!!
Other factors I would consider would be what the purpose of the car? Are you commuting in traffic as a daily, weekend country roads, or track car?
The other reason I went with auto was because I live near Toronto, I have pretty much exclusively driven manual my whole life and it's a much more connected feel to the car and road. But when you're driving the on the DVP and constaintly shifting 1st, 2nd, 1st, 2nd, 1st, 2nd, 3rd, 2nd, 1st, 2nd, 1st, 2nd, 1st, etc... In those moments you are already hating life and pissed off at the whole world for cutting you off. The auto is just one less annoyance! If I lived further out I most likely would of rolled the dice on a 4+3.
As you can tell, and as the thread has stated before me, It really depends on you, each have their pros and cons, you just got to find what one has more pros for you!
