INTERIOR LIGHTS
Old Jan 30, 2003 | 03:59 PM
JIMSZ71's Avatar
JIMSZ71
1st Gear
Default INTERIOR LIGHTS
THE INTERIOR LIGHTS IN MY 84 DON'T COME ON WHEN EITHER DOOR IS OPENED BUT DO WHEN THE HEAD LIGHT **** IS TURNED.THE DOOR SWITCHES TEST GOOD.COULD THIS PROBLEM BE THE INTERIOR LIGHT TIMER & WHERE IS IT LOCATED ?
Old Jan 31, 2003 | 01:49 AM
WEB_War84's Avatar
WEB_War84
Default Re: INTERIOR LIGHTS (JIMSZ71)
I have the same problem, but no solution
Old Jan 31, 2003 | 01:56 AM
paintdaddy's Avatar
paintdaddy
Default Re: INTERIOR LIGHTS (WEB_War84)
I wont say for sure but I had this problem with my 88 and it turned out to be the timer/delay switch. :seeya
Old Jan 31, 2003 | 02:37 AM
DarkHalo's Avatar
DarkHalo
From: SCMR Rat Pack'r Charter Member, Inland Empire Chapter
Maybe its THAT JAMMED CAPS LOCK KEY CAUSING THE PROBLEM.....*hands JIMSZ71 a pry bar*
Old Jan 31, 2003 | 06:54 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: INTERIOR LIGHTS (DarkHalo)
:lol: :lol: :lol: :withstupid:
Old Feb 2, 2003 | 01:39 AM
jfb's Avatar
jfb
The left and right door jamb switches have white wires on them and if you have determined that the switches are ok and are being activated by the door, then your next test is to determing if the switch grounds are good. Jump the white wire to ground and see if the interior courtesy lights come on. If they don't , then you have a defective courtesy light delay timer. The door jamb switches when grounded (door open), tells the delay timer to ground the interior lamps which turns them on. Your headlight control grounds the lights by itself.
Old Feb 2, 2003 | 07:39 PM
1-MORTOY's Avatar
1-MORTOY
The delay timer is behind the carpeted knee panel on the passenger side, close to the ECM, at least thats where it is on my 85. :cheers:
To INTERIOR LIGHTS
