FX3 initial installation, what way should the shock knobs be turned?
Old May 11, 2024 | 01:59 PM
dizwiz24's Avatar
dizwiz24
Default FX3 initial installation, what way should the shock ***** be turned?
Im getting ready to put FX3 shocks and actuators back onto a 1993 6spd fx3 coupe that had the system removed (thank you ChumpVette for the parts)
i noticed the ***** on the top spin 180 degrees.
i am working on the rear shocks at the moment.
what way should these ***** be turned at installation ? Full clockwise? Full counterclockwise?
it doesnt look like i can turn the actuators.
but i wonder if i should have them perhaps disconnected , from the shock, when i key-on so that its gear can ‘reset’ before placing them onto the shock top.
and where should fx3 **** selector be at? Soft? Performance?
Or does none of that really matter
also, the FSM mentions that the selector gear should protrude 4.5mm min above the top of the cup assembly , on the shock.
while this does seem correct for the fronts, it doesnt seem correct for the rears (see photo) and i am going to assume a typo in the 1993 FSM red book 1
See how the selector gear is more or less flush wirh the top of the cup, and not 4.5mm above it
Rear shock part number
Old May 11, 2024 | 02:55 PM
ChumpVette's Avatar
ChumpVette
Doesn’t matter which way. The system does a self check rotation each way to orient itself at key on.
Old May 11, 2024 | 09:55 PM
dizwiz24's Avatar
dizwiz24
Should the **** be greased ?
im not talking with black greasy molybdenum sulfide stuff you’d put on a wheel bearing
But clear water resistant grizzle grease that i used to use when i had a yamaha wavereunner
Old May 12, 2024 | 12:56 PM
ajp01's Avatar
ajp01
No grease needed, the female receiving gear in the actuator is made of nylon plastic normally and it doesn't require lubricant. 4.5mm sounds about right, if it's any higher it won't allow the actuator to seat correctly on top of the shock and the snap retainer ring won't be able to snap into position. So if you have to err, less than 4.5mm is better than more than 4.5mm.
It doesn't matter which setting the control **** is positioned, as Chump mentions the system does a full rotation check from stop to stop when you start the car. If the controller sees any actuator that doesn't have correct rotation range from full soft to hard, at the right rotation range of degrees, it'll set a code and the light will come on.
Be advised, the 1992 and later controllers / shocks were much less than 180 degrees rotation range on the top of the shock. See this post from me where I describe the differences in the models pre- and post- 1992. https://www.corvetteforum.com/forums...post1606991733
Your FX3 controller should be matched to the right year/model shocks. If your shock gears on top of the shock turn almost 180 degrees, they are the older shock from pre-1992 and should have the right controller to work properly.
To FX3 initial installation, what way should the shock knobs be turned?
