Door compatibility
Old May 13, 2024 | 09:37 PM
RubyJim's Avatar
RubyJim
4th Gear
Default Door compatibility
Hey guys. I'm newly registered but I've been using this site for a few yrs now and it has helpful more than words can say. I have a 93 ruby. It's my first time owning a vette. It's been quite an experience. I have a question about door compatibility. My drivers door was backed into and badly damaged. I found a 1987 door but it seems there are small differences and I'm having a hard time putting it on my car. Will a 1987 door properly fit a 1993 car?
Old May 15, 2024 | 02:30 AM
slammin's Avatar
slammin
The door may fit, but the interiors changed in 1990. The door panel won't match the passenger side and the door panels aren't interchangeable. I am sure there are less obvious differences. Here is a compatibility chart by Mirrockcorvette.
https://mirrockcorvette.com/c4-parts...#interior-trim
Old May 15, 2024 | 06:39 AM
'78CorvetteS.A.'s Avatar
'78CorvetteS.A.
I believe, for it to be a true "matching" replacement, you'll need a door from a '93-'95.....you may get others to work, but to be physically identical, inside and out....that's what you need👍
Old May 15, 2024 | 11:23 AM
RubyJim's Avatar
RubyJim
4th Gear
Thank you for the info. I did get the door hung so that it opens and closes nicely. But it has no weather seals and no inside panel. That's what I get for not doing my research first. Hey have a great day guys. Thanks again for the info.
To Door compatibility
