Stalling Issue
Old May 17, 2024 | 12:23 PM
lorenzo1987c4's Avatar
lorenzo1987c4
Default Stalling Issue
Hey all,
I have a 1987 Corvette, automatic, 57,000 miles. Recently, I’ve been daily driving it since my daily was totaled. Here’s what I’m dealing with…
Usually once a week, if i’m giving the car some throttle, it’ll cut power until i release the gas and then press it again. I’ll then get a service engine light and then the car would run weird. this usually resets after i shut the car down for a while then it goes back to normal until the next random occurrence. haven’t read the code yet but it bet it’s 32 or 34.
today, i was at a traffic light stopped, when it turned green, i let off the brake and the car stalled leaving me to put it in park and start it back up.
what i’ve replace in the last two years:
Plugs, cap, rotor, wires, fuel filter, IAC valve, EGR valve, cleaned the TB and repaired two vacuum lines, (checked those for leaks)
I thinking at this point it’s either the fuel pump or injectors but I’m a self taught “mechanic” so any pro advice would be helpful. i was going to use an injector cleaner treatment and clean the MAF to see if that makes it better as well.
let me know what you guys think.
Thanks!
Old May 28, 2024 | 04:37 AM
Cloud_Jumper's Avatar
Cloud_Jumper
if thats all clear....maybe look into the ECU? make sure nothigs corroded there or anything
