Door sill protector install
Old May 23, 2024 | 01:52 AM
Bonezz70's Avatar
Bonezz70
Default Door sill protector install
I ordered sill protectors from Amazon. Less than impressive. Thin cheap plastic, but they should do the job. Before I start drilling anything, what’s the proper way to secure them? If my foot brushes against it, it flops right off. I’m thinking I need to drill a couple holes in each protector, and using shallow metal screws, just screw them in? There aren’t any pre drilled holes but that seems to be the only solution.
Old May 23, 2024 | 08:34 AM
Wildride's Avatar
Wildride
Cruise-In II Veteran
I used one short stainless steel oval head screw (#10) with a cup washer on each protector. One screw on each has done the job for the past 30+ years.
Old May 23, 2024 | 08:39 AM
KMS88Cal#16's Avatar
KMS88Cal#16
I have a pair of plastic sill protectors. I am going to use the self adhesive Velcro strips on them to hold onto the carpeted sills. Kevin
To Door sill protector install
