C4 door repair or replace
Old Jun 17, 2024 | 11:33 AM
rkjjeep's Avatar
rkjjeep
Default C4 door repair or replace
Looking for informed and kowledgeable advice. We picked up this C4 partly to help someone out and the passenger side door outer panel AND shell is damaged on the lower rear corner. The damage on the outer panel looks repairable. Sorry about the flash light reflection on the panel photo. The damage on the shell is a pretty significant crack where the two edges of the crack are not lined up (about 1/16 offset to each other). That crack runs from the panel outer all the way to the door seal. Is this likely repairable or should I just pick up a door in better shape and swap the pieces over? I haven't had great luck finding an experienced person to do the repair. Not gonna flip the car - I really like it and other than this it is in excellent shape mechanically and cosmetically. It's a keeper.
Old Jun 17, 2024 | 11:34 AM
Rush91's Avatar
Rush91
I would shop around for a used door. But that's just me.
Old Jun 17, 2024 | 11:54 AM
Topduarte's Avatar
Topduarte
I have a white undamaged door. Let me know if you decide to do that route.
Old Jun 17, 2024 | 04:07 PM
Z51JEFF's Avatar
Z51JEFF
Replace the door. It's a lot more work than trying to fix that crack. Another option is replacing the door skin. Doors are everywhere and dirt cheap.
Old Jun 17, 2024 | 04:24 PM
WVZR-1's Avatar
WVZR-1
Replace the door - you haven't mentioned year but if it's '91 or newer get a '91+ door as the glass is different than '90 and earlier. It will be much easier aligning the glass using a used door vs transferring your glass and hardware to a used door of any other year. It would be great also to maybe consider paying premium for a door of the correct color.
Post back mentioning year and the color code from the SPID label. You don't have a location in your 'profile' so add that also.
** Is there any damage to the door opening of the body?
Old Jun 17, 2024 | 04:46 PM
rkjjeep's Avatar
rkjjeep
Location is Gregory MI. C4 is a 1994. It is code 41 black. Thanks!!
Old Jun 17, 2024 | 05:40 PM
WVZR-1's Avatar
WVZR-1
Shop here on the forum posting a WTB with that information and if you'd like to shop 'local' just to see what might be out there try
https://www.car-part.com
*** remember any JY or salvage the price they post is very negotiable ! very negotiable !
Old Jun 21, 2024 | 08:38 PM
rkjjeep's Avatar
rkjjeep
Thanks everyone I found a nice door and will have masterworks near Detroit paint it and swap it out.
To C4 door repair or replace
