Tachometer not correct.
Old Jul 17, 2024 | 08:40 AM
DoctorG17's Avatar
DoctorG17
Default Tachometer not correct.
My tach reads higher then what the engine is doing 1990 c-4?
Old Jul 17, 2024 | 10:17 AM
ToniH's Avatar
ToniH
That is a common fault, they all break sooner or later and that is a common problem with the newer style of gauges (90-). Batee will repair yours or you can fix it yourself with their parts.
Old Jul 17, 2024 | 04:43 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
You will need to provide a resistor to correct the high tach reading.
Here ya go ... https://www.corvetteforum.com/forums...ch-repair.html
Old Jul 17, 2024 | 05:20 PM
slammin's Avatar
slammin
My 91 shows 2000 rpms at idle. I hoped there was a simple fix, but nothing is simple on a C4. Batee has a repair video and sells the parts. The repair looks easy, once you pull the panel from your car.
To Tachometer not correct.
