(Help) Coolant hose exploded, which part?
Old Jul 27, 2024 | 04:18 PM
sharpnif.l98's Avatar
sharpnif.l98
Cruising
Default (Help) Coolant hose exploded, which part?
So this just happened to my coolant hose. It looks like the previous guy tried to repair it with a plastic hose and clamps.
My rpm’s were high and sluggish acceleration (just saw an oil leak earlier that day) so I was going to the auto store to top off oil,then it started smoking and exploded, coolant leaked everywhere. Thankfully a nice police officer and a family helped me push it to the gas station.
I'm wondering which replacement hose I’ll need if anyone has specifications.
Old Jul 27, 2024 | 04:32 PM
sharpnif.l98
Cruising
https://www.ecklers.com/1988-1989-co...B&gclsrc=aw.ds
Would this work or should I get just a hose? Is it a hard
repair?
Old Jul 27, 2024 | 06:42 PM
IHBD's Avatar
IHBD
Pro Mechanic
The hose in the Ecklers link is not correct.
That plastic that failed is a "Flush" fitting that was inserted in the hose. Use "radiator flush kit t fitting" for a search. There are a gillion hits. You need one for 5/8" hose.
EDIT; I looked again, and I can't tell which diameter hose that is. There is a 5/8" and 3/4". You can compare the two hoses that are side by side, the larger diameter is the 3/4". (Duh.)
A quick fix would be go to the home depot or hardware store and obtain a 3 or 4 inch long pipe nipple. The O.D. of 3/8 pipe is 5/8", the O.D. of 1/2" pipe is 3/4". Get the size nipple that works with the hose diameter that needs repair. Loosen the clamps, remove the broken plastic, and insert the nipple equally into each hose. Tighten the clamps. The repair will probably last indefinitely, or at least as long as the hose does.
Old Jul 27, 2024 | 06:56 PM
belairbrian's Avatar
belairbrian
The repair is fairly simple. Just replace the hose and refill the cooling system.
The hose is a bit trickier. Depending on options, one of two possible hoses is needed. Easyiest way to determine which configuration you need is to follow the hose to the water pump. Depending on whether their is a second tee connection in the line or not, will determine which hose you need.
I had one of the big hoses spring a pinhole leak oneday on the way to work. Managed to tape it up and get home. At that point I changed out every hose, seeing how they were over 25 years old.
Old Jul 27, 2024 | 08:18 PM
typical boomer's Avatar
typical boomer
I agree with IHBD. I have the same fitting from a PO on my '84.
Took this pic documenting a new EGR valve. the gray **** at the bottom is the cap of the flush fill tee.
Old Jul 27, 2024 | 11:54 PM
sharpnif.l98
Cruising
hey man thank you, I was 30 minutes away from home so went to the auto store and they had a kit so did that and filled coolant back up, no leaks, pumped it etc.
I got the car 4 weeks ago and was doing stuff as I go (flushed brakes, got valve cover gasket (leaking), and fuel pump)
After fixing the leak, seems like I had another issue happen on top of each other? In D and overdrive it revs but doesn’t accelerate, it’ll give it a little bit of a jolt then just revs. 2nd gear actually accelerates but it drove very rough, whenever I gave it less gas it felt like it wanted to quickly slow down? not sure how to explain it. Oil temps ended up sitting at 265 on the highway and coolant hit 240. Is my trans crapped on? Or what else can it be?
Also when changing gears you can feel the trans (car shakes?) again don’t know the terminology but changing gears jolts the car
trans fluid seems way overfilled as well
Old Jul 28, 2024 | 01:22 AM
JETS C3-C4's Avatar
JETS C3-C4
Are you checking the trans fluid with the car running? Just a thought.
Old Jul 28, 2024 | 01:25 AM
sharpnif.l98
Cruising
Originally Posted by JETS C3-C4
Are you checking the trans fluid with the car running? Just as thought.
this was maybe 3 hours after parking it home, so not running
Old Jul 28, 2024 | 01:49 AM
JETS C3-C4's Avatar
JETS C3-C4
F.Y.I.
If not running it will show over full. Automatic transmissions fluid level is checked with the engine running and NOT in gear.
Old Jul 28, 2024 | 01:51 AM
sharpnif.l98
Cruising
F.Y.I.
that makes more sense thank you 😂!
Guess I’ll have the shop check it out and see what it may be.
To (Help) Coolant hose exploded, which part?
