Filthy gas tank
Old Aug 2, 2024 | 05:00 AM
rhandle's Avatar
rhandle
Default Filthy gas tank
I have a 96 vette that has been sitting for 2 + years due to health issues. Apparently the fuel sending unit and fuel pump rusted out from the ethanol containing fuel. The gas evaporated out and i am left with a caked on rust powder residue at the bottom of the tank. THE TANK ITSELF NOT RUSTED. How do i clean this mess up. What kind of a solvent or cleaner do i use to loosen this residue up.?
Old Aug 2, 2024 | 07:02 AM
Whaleman's Avatar
Whaleman
I am reading your post and if the gas was above the whole sending unit and rusted it and then evaporated all out in just two years is hard to believe. I don't think this is possible even with the gas cap off. Have you tried just reaching down with a rag with maybe mineral spirits on it? Dan
Old Aug 2, 2024 | 08:03 AM
Raidmagic's Avatar
Raidmagic
Just spray some carb cleaner or brake cleaner in there and wipe it out with a rag. I recently went through this with mine as it sits a lot. Once you get the sender out there is a lot of room to reach in there. Even some fresh gas would work to wipe it all out. It's a pain but more than doable.
Old Aug 2, 2024 | 10:41 AM
2011KLR's Avatar
2011KLR
If it is powdery, id try to attaching a brush or scrub pad to the end of a stick and loosen as much as possible. Then shop vac it out. And as a last step damp wipe it out as described above.
To Filthy gas tank
