DIY Camber Brace
This is the Hard Side. Not much room to Snake any Metal between the PS Pulley. The PS Tank has been moved outboard as far as it can go for more room. It's now bolted to the Camber Brace. The big Hose needed to be extended a bit.
This is the Easy Side. The Radiator Hose now runs under the frame. No it didn't work I needed to go look in the back of the auto parts store and pick one with a better shape to it.
