Extreme pinging
Old Aug 17, 2024 | 11:32 PM
Ekays's Avatar
Ekays
Default Extreme pinging
As the title states, I've been experiencing hard pinging. I have a 1989 ZF6 L98. Currently driving from western Washington to Southern Arizona. I've been passing through alot of different weather but the trend is significantly hotter than I'm used to. My c4 normally runs at ~170° (I've heard this is oddly cool). All the way through Nevada and now northern Arizona it's been running at 200-230° depending on the ambient temperature (today it was mostly 100+). The severity of the pinging changes with how hot the engine is. Below 190-200° I can get away with quarter throttle or more without any pinging. If temperatures rise above 210 I'm lucky to get 1/8th throttle without pinging. When cold or below 160° I have 0 ping even under WOT. I've always ran 92 or higher octane (even though most people on here say that's unnecessary). I tried 2 bottles of octane booster in Las Vegas with no change throughout the rest of the day. I suspect my timing was advanced (mechanically at the distributor) by a previous owner for cooler temperature and much lower elevation. I normally am at 500 or less feet and have been driving through 5000+ feet of elevation all day. I have to keep driving tomorrow, but I also cannot let my poor corvette continue to eat itself. I'm at a hotel, but I brought tools and I'm considering retarding the timing by hand in the parkinglot and seeing if I can get the knock to go away. I've seen it done by loosening the distributor and turning it by hand but most people mention using a timing light so I'm not confident about this strategy. Let me know your thoughts, I need a solution!
I dont belive this is related but I recently replaced the knock sensor. The car also has 146k on it which made me consider alot of built up carbon but the octane booster did not effect the pinging so I've dismissed this idea.
Help!
Old Aug 18, 2024 | 12:01 AM
ULTM8Z's Avatar
ULTM8Z
A bad or incorrect knock sensor won't actually cause pinging. Though it could prevent the ECM from adjusting the timing to mitigate it.
But from what you're describing, that's an abnormal amount of pinging.
The theory about someone having advanced the timing at the distributor is plausible. But I would caution against adjusting the timing w/o a timing light. Maybe if there's a Harbor Freight or auto parts store nearby, go get a cheap timing light to do the adjustment.
You're correct that you'd loosen the bolt on the clamp at the base of the distributor to allow adjustment. You'd then disconnect the EST connector prior to starting the car. Factory timing should be 6° BTDC.
If the previous owner advanced the distributor, to say, 20° or something (without adjusting the calibration in the ECM to match it), that would essentially blindly add 14° to everywhere in the spark timing maps.
Old Aug 18, 2024 | 12:55 AM
John S 1961's Avatar
John S 1961
Use only gm ac Delco OEM knock sensors. They are a very sophisticated and sensitive device
Old Aug 18, 2024 | 01:22 AM
Ekays's Avatar
Ekays
That's actually a good point. i did no use oem... you might be onto something. Also thinking back I didn't torque it. I learned recently that they are sensitive to torque and never actually went back to check the torque spec
Old Aug 18, 2024 | 08:48 AM
ex-x-fire's Avatar
ex-x-fire
My sure the egr system is working correctly.
Old Aug 18, 2024 | 09:42 AM
arbee's Avatar
arbee
Help!
Your idea of retarding the timing to test is a valid one. You do not need to go and spend money on a timing light. Use a scribe to mark its present position and turn the distributor. It can then always be turned back to where it was. A bit of late timing will hurt nothing.
Old Aug 18, 2024 | 12:08 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
why did you replace it?
Old Aug 18, 2024 | 12:28 PM
Ekays's Avatar
Ekays
Good point
When flushing the coolant I removed it to drain the block, the end snapped off in the block and I had to weld a nut onto the remaining chunk. After that it wasnt so great at detecting knock
Old Aug 18, 2024 | 01:00 PM
rremesal's Avatar
rremesal
Stop the presses!
There is a great possibility your knock sensors are at fault. They are too be torqued down ONLY 14lb/ft.
If you go tighter than that, your car will ping as the sensors become ultra sensitive.
Loosen up and properly torque your KS.
Old Aug 18, 2024 | 01:15 PM
Ekays's Avatar
Ekays
Originally Posted by rremesal
Stop the presses!
I definitely went tighter than that 🤡 guess I'll go buy some jack stands real quick. Hopefully the auto parts store will loan me a torque wrench
ULTM8Z's Avatar
ULTM8Z
The knock sensor does not cause pinging.
If the OP is pinging that badly in the first place (especially at only 1/4 throttle) something else is wrong.
Old Aug 18, 2024 | 01:34 PM
Ekays's Avatar
Ekays
Doesn't hurt to check though right? I have to keep driving today
Old Aug 18, 2024 | 01:36 PM
ULTM8Z's Avatar
ULTM8Z
Certainly not. Just saying that your problem most likely is elsewhere.
Also agreed on getting a GM sensor. While Likely still made in China, they do seem to deliver better results than aftermarket.
Old Aug 18, 2024 | 01:43 PM
Ekays's Avatar
Ekays
Acdelco sensor is my next step, it's 182 miles away though. Nevada and arizona are real empty
Old Aug 18, 2024 | 03:43 PM
Ekays's Avatar
Ekays
Update, correctly torqued knock sensor. No change
Old Aug 18, 2024 | 05:23 PM
tequilaboy's Avatar
tequilaboy
A bad knock sensor can most certainly cause knock in 86-89 cars.
Are you getting a Code 43?
If no knock is detected during an ignition cycle, the ecm will add timing in an attempt to force it to knock until a Code 43 is set. This knock sensor function test only occurs under relatively high load (LV8 > 190) and hot coolant ( coolant temp > 194 °F). The ecm will ramp up timing and can add up to 25 degrees advance during the function test. It takes 3.9 seconds for Code 43 to mature, so the engine may be exposed to excessive advance and real knock which may cause engine damage prior to setting Code 43.
You can either stay on the gas until it sets a Code 43 (risking damage) or disconnect the knock sensor which should cause a Code 43 to be set. The ecm will retard the timing by 8 degrees while Code 43 is active and should keep things relatively safe until you can set the timing properly.
Old Aug 18, 2024 | 05:35 PM
tequilaboy's Avatar
tequilaboy
Another band-aid solution would be to run it in diagnostic mode by shorting ALDL Pins A and B, which will result in fixed timing of 20 degrees advance. This would not be ideal, but should be safe.
To Extreme pinging
Old Aug 18, 2024 | 06:30 PM
Ekays's Avatar
Ekays
No code, based on what you said the car has been given the opportunity to set it but hasn't. Sounds like I should disconnect the knock sensor for now. I am getting close to getting an acdelco sensor in about another hour or so.
Sounds more complicated than disconnecting the sensor, any benefit of doing this instead?
By not ideal do you mean worse gas mileage and performance? Thats fine by me ive been getting 20-25 mpg which is much better than most cars ive had. Id take the hit to save the engine
Old Aug 18, 2024 | 06:42 PM
tequilaboy's Avatar
tequilaboy
Doesn't get much simpler than a paperclip. 20 degrees of fixed timing should idle and run just fine, but performance and fuel economy will suffer a bit.
Note: if the mechanical timing has been advanced (beyond 6 degrees), this will add an offset to the 20 degrees fixed timing.
Old Aug 18, 2024 | 09:30 PM
Ekays's Avatar
Ekays
Read the codes (had to replace ses light). I have an egr code (32). Then I unplugged the knock sensor. Haven't read the codes since but it still pings the same amount. Also the ses light does not stay on after taking it out of diagnostic mode, would've thought it would stay on while driving. Nor sure what to do from here. Kinda seems like it's a fuel issue since unplugging the sensor didn't work. Could a clogged filter or bad fuel pump be the issue? Still have 2 hours left to drive today
