White smoke from engine 87 corvette
Old Aug 24, 2024 | 12:33 AM
C4formore's Avatar
C4formore
Default White smoke from engine 87 corvette
So I just got my restoration project running, all the coolant had been drained when I replaced practically every sensor and drained the radiator for old coolant. Although I also installed an egr delete which supposedly makes the engine run lean. There's been white smoke coming out of my engine pretty consistently and I'm not sure why. Would the egr delete be that serious to cause the white smoke or do I just have to wait for the new coolant to recirculate. My gauge still says low coolant and ive been adding more and more every time i start the engine for 30 ish seconds... Sorry if these questions seem obvious, I just want to make sure I don't mess anything up as I've been working on this project for a long while...
Old Aug 24, 2024 | 07:40 AM
Whaleman's Avatar
Whaleman
What does your oil look like? Dan
Old Aug 24, 2024 | 08:16 AM
glbeauchamp's Avatar
glbeauchamp
White smoke can be indicative of a coolant leak into the combustion chamber. Head gasket perhaps?
Old Aug 24, 2024 | 05:52 PM
C4formore's Avatar
C4formore
I did change the head gasket out actually although I think I may have tightened it down too much and I'm starting to think it is a coolant leak...
Old Aug 24, 2024 | 05:53 PM
C4formore's Avatar
C4formore
oil is fine I did an oil change not even a month ago although there was some buildup as it's been sitting for a while
Old Aug 24, 2024 | 09:33 PM
glbeauchamp
Proper torquing sequence and poundage is very important when tightening head gasket to the head . Hopefully that's what is wrong. Fairly easy fix
Old Aug 24, 2024 | 09:43 PM
killain's Avatar
killain
Oldtimer
There is a kit ( I think it can be rented ) that fits over at the radiator and you use it to find out if you have a leaking head gasket. You install it on the radiator and insert a dye into the tool and run the engine and if the color changes, there a problem with a leak of exhaust into the cooling system. I'd look it up, I think it canbe rented at Autozone or other tool outlets. Sorry i don't have the full information on it.
Good luck !
Old Aug 25, 2024 | 05:02 PM
449er's Avatar
449er
CF Community Team
Well stated
Old Aug 26, 2024 | 09:51 AM
John S 1961's Avatar
John S 1961
Pressure test the system it should hold 20 lbs for 30 minutes. If not then.......
To White smoke from engine 87 corvette
