"change oil" notification ?
Old Aug 25, 2024 | 08:43 AM
cv1988's Avatar
cv1988
Default "change oil" notification ?
Had my oil and filter changed 200 miles ago,on my 1996 coupe.When driving since then, there is a lit up message to "CHANGE OIL" that is on at all times.Never had this happen before.
Shows up on the left side of the instrument cluster.How can it be eliminated ? Shop manual & owners manual have no mention of this. TIA
Old Aug 25, 2024 | 08:46 AM
Whaleman's Avatar
Whaleman
Whatever you want to do youtube has a video on how to do it. Dan
Old Aug 25, 2024 | 08:47 AM
Whaleman's Avatar
Whaleman
The owners manual DOES explain how to do it. Dan
Old Aug 25, 2024 | 10:11 AM
cv1988's Avatar
cv1988
Default thanks
thanks for the info-much appreciated.
Old Aug 25, 2024 | 07:18 PM
Torqsplit's Avatar
Torqsplit
I followed the owners manual instructions for my 96 aswell. Just know, it will reset your trip meter and fuel avg info when you do it. If that's a concern for you. Just FYI 🍻
Old Aug 26, 2024 | 07:03 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Yes, both of them explain exactly how to reset that light.
Right out of the 1996 Owners Manual:
Old Aug 26, 2024 | 07:12 PM
IHBD's Avatar
IHBD
Pro Mechanic
Rather than look it up, memorize how to do it: Turn key to RUN. Do not start engine. Push and release ENG/MET twice. Press and hold GAUGES until Change Oil light stops flashing and goes off. The minder is reset.
To "change oil" notification ?
