Heater core replacement
Old Sep 12, 2024 | 12:35 PM
jamesgilbert's Avatar
jamesgilbert
3rd Gear
Default Heater core replacement
I have a have a 1988 c4 I having problems with the heater core need to be replaced does that come out through the dash or does it come out off under the hood what would be the best way to take that out what tools will I need and when I replace it will that also correct the vacuums because I can't get the AC to blow out the vents it only go out of the defrost on the window please help my name is James Gilbert my number is 979-595-5582
Old Sep 12, 2024 | 01:16 PM
drive it's Avatar
drive it
It comes out under the dash and can be a pia.As for the other problem-is yours the electronic AC or manual?
Old Sep 12, 2024 | 03:24 PM
jamesgilbert
3rd Gear
Is electronic
Old Sep 12, 2024 | 06:55 PM
Siveck's Avatar
Siveck
Two different issues there. Fortunately, the pre 90 cars have easier access to the heater core. Still difficult. The programmer above throttle pedal is likely the issue for air flow to vents. Lots of info about both operations on the forum.
Old Sep 12, 2024 | 10:24 PM
C4 Steck's Avatar
C4 Steck
I don’t envy you. But we will all be there one day, sooner or later. If I recall correctly, there was info on what brands were good and had good fitment. You might want to check into that before you go buying just any one. It would suck to have fitment issues when you are already doing the contortionist bit under the dash.
Old Sep 13, 2024 | 06:37 AM
mark4cam's Avatar
mark4cam
I just did this job and while your early car will be a little different, if you take your time and keep track of things, it's really not that difficult. Just lots and lots of fiddly things to take apart. Do a little googling and you will find resources for the early cars too. I bought mine from Rock Auto and it was $36 shipped to my door. Cheap part, pain in the *** job.
https://www.corvetteforum.com/forums...post1608110485
Old Sep 13, 2024 | 10:08 AM
vader86's Avatar
vader86
Its under the dash, and you will curse a lot at GM for building the entire car around the heater core.
Old Sep 13, 2024 | 06:39 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
Step 1 at the assembly plant, levitate the heater core in the air
Step 2, tightly enclose it with as many parts as possible requiring contortionist skills so the entire caged assembly eventually resembles a car
Old Sep 13, 2024 | 07:28 PM
mark4cam's Avatar
mark4cam
Lol you guys are making it sound so bad. It’s really not a difficult job. Just have to take a LOT of stuff apart. Take your time, note where everything goes, and it’s not too horrible. The worst part is cleaning up the mess left by the blown core.
Old Sep 14, 2024 | 06:49 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Pro tip; take your passenger seat out so you can get better access. Your lower back will thank you.
Old Sep 15, 2024 | 07:15 AM
larrybud's Avatar
larrybud
I've done this twice in my 86. 2nd time was easier. You have to take nearly everything out on the passenger side interior dash to access it: Dash pad, air ducts (right side), hush panel, ECM. The hardest part for me was a steel brace on the right side. One of the bolts was a pain to get back in.
Tools are minimal and basic, screw driver, ratchets, sockets. Do yourself a favor and take the passenger seat out for "easier" access.
I'd recommend getting the factory service manual. It lists everything step by step. It's not difficult, per se, just a lot of stuff that needs to be taken out.
One thing: In my 86 there are two pairs of connectors under the dash which can be accidentally plugged into each other, making the car non-startable. Took me forever to figure out why I couldn't start the car (actually sat for years, due to lack of time to figure this out). Why they used the same connector I don't know!
Old Sep 15, 2024 | 02:47 PM
Siveck's Avatar
Siveck
I did this in 2011 or so on my ‘89 roadster. 2002 on my prior ‘89 coupe. What I remember the most from both was the one screw that is impossible to see. I think I used tape on the socket for the reinstall. Top side of the box, I think. Dash frame in place.
Funny memory: I had the roadster several years before the heater core replacement. Wife always said there was too much hot air in passenger footwell. Dismissed it every time. During heater core replacements, I found the issue. Heater core cover had a big crack/ hole in it. Then came the told you so.
Old Sep 16, 2024 | 11:28 AM
larrybud's Avatar
larrybud
I wouldn't have even told her that....
Old Sep 16, 2024 | 09:15 PM
Siveck's Avatar
Siveck
Wish I could go back and advise the young version of me.
Old Sep 23, 2024 | 02:12 AM
MrRenoman's Avatar
MrRenoman
Did mine recently. Good thing I took out the dash while cleaning the car mice fluff and stuff. Still a little fiddly with the aftermarket core and the spring clip.
Old Sep 24, 2024 | 05:55 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Look up "The Fast Guy Method" to change the heater core on a C4 Corvette. It's step by step instructions and fairly simple. It will save you lots of time and aggravation. You can do this job just by removing the passenger seat and knee carpeted hush panel on the passenger side. You'll be laying on your back on the floor and then you'll be able to see everything you need to move out of the way under the dash. The heater core cover is the tricky part to remove. It's held on by about 6-8 bolts. Remove the lowest cover bolts you can see and reach and then wiggle the cover back and forth to break the remaining top hidden bolt holes open. They're impossible to see and unscrew. No one will ever see them again and you really do not need ALL those bolts to hold the cover back on. NO NEED TO REMOVE THE DASH OR CONSOLE! I completed this job with simple tools in about 8 hours. Good luck!
Old Sep 26, 2024 | 02:58 PM
Georgerx7's Avatar
Georgerx7
4th Gear
I had a problem with my heater core. I just flushed mine, instead of replacing it, and now my heat works. It's much easier.
Old Oct 2, 2024 | 08:26 PM
larrybud's Avatar
larrybud
I think most heater core problems aren't a no-heat issue, but that it's leaking coolant into the passenger side of the cockpit.
To Heater core replacement
