does it go out when hot :-(
i am new to the forum
I have a 1984 corvette that as soon as I start it up and until it gets to 170 degrees it is fine then it starts to shut down as soon as I put it in gear. It has an automatic transmission. Can anyone help me, thanks in advance
If you start the car, the ECM is in open loop operation, its only reading Coolant temps and deciding the fuel pulse widths based on that and throttle body position. It ignores other readings essentially. Once a timer expires and it sees temp readings hit the right range, it starts listening to all the other sensors. If some of them don't make sense to it, it can run like a dog or not at all.
The CTS sensor can be a culprit, but you really need to look at several things if it becomes a closed loop problem. If a code is set you need to pull it.
You should also have an 84 Helm Factory manual, you will need one.
As long as it doesn't flood, it is easier to start cold because the lower the temperature, the more the ECM increases fueling. The ECM will interpret the unplugged sensor as its maximum coldest temperature calibration for fueling.
You have some other idle speed control anomalies. (I hope that word translates correctly.) The high idle speed until it warms up, the shut off at a certain temp when taken out of Park leads me to suspect that you have a bad ECM. My personal experience has been that the ECMs I've replaced (not that many) have been for idle control issues. Read on.
The ECM has several routines for Idle Speed Control. One of the inputs is the P/N switch. When in P/N and closed throttle the ECM controls the IAC to a pre-determined RPM. At cruising speed, when the throttle is not at idle, the ECM commands the IAC open a predetermined amount so that if the throttle is closed suddenly, a stall won't occur. The ECM uses the P/N switch input to control the IAC appropriately.
Obtaining a 1984 ECM in Italy may be challenging. I would try this, as it will cost nothing. Remove the top plate on the center console. (You don't have to remove the shift ****, just lift and twist the top plate out of the way.) Find the orn/blk and the blk/wht wires going to the P/N switch. Make a little jumper wire with stripped ends and stuff them into the connector cavities for these two wires. Be sure stray strands don't touch adjacent cavities. Put the top cover down and try it. If the engine no longer turns off at 170F, it is probably the ECM. If the car is driveable with the jumper in place, you can drive it, but stalling with a sudden close of throttle may occur. EGR and cannister purge will also not occur, but these probably aren't a concern in Italy.
You may have a bad ECM. Try jumping the orn/blk wire to ground and see if it stays running when taken out of Park.
What do you think?
Jumper the diagnostic connector A and B. Start it up. Watch the Check Engine Light (CEL) and the temperature. When in OPEN Loop the CEL will flash at about 3 flashes per second. In CLOSED Loop it flashes at about 1 per second. As it warms up, watch the CEL. See if it goes into closed loop prior to 170F. It should.
Have you checked for Diagnostic Codes? Jumper the same A and B. Turn key to RUN. Watch the CEL. It will flash each code beginning with "12" which is flash----flash-flash,,,,,,,,,,,flash----flash-flash..
Each code is displayed 3 times then the next one. When Code 12 is again displayed, or if only 12 is displayed, there are no further codes.
Code 13 is Oxygen Sensor. Code 14 and 15 are Coolant Temperature Sensor Codes. If you have other codes, report back, or there are many sources online that have the code descriptions.
F - E - D - C - B - A
G - H - J - K - L - M
When starting the engine the CEL flashes quickly until the temperature shows 115 degrees F. then it starts flashing slowly. Does this mean it goes into closed circuit mode at 115 degrees F? What can I do? I was thinking of replacing the oxygen sensor...
Does it stay remain in Closed Loop (flashing slowly) until it turns off at 170 F?
When it turns off at 210, is it always at 210, or is it always when the fan starts?
Try this, please: Unplug the fan switch. Watch the temp rise. Allow the temp to get to 220F, and if it does without turning off, that's a hint that the defect has something to do with the load of the fan on the alternator. Plug the switch back in to run the fan to allow the engine to cool before turning it off with the key.
Last question for now: When it turns off is it sudden, like using the key, or gradual like it ran out of gas/petrol?
The car up to about 115 F has the minimum at 1800 - 1900 rpm and then slowly drops to 900 800 rpm as the temperature rises and then turns off, but if I put the gear in, at this stage, the rpm drop drastically and it turns off. I manage to restart it and bring it to the point where the fan starts but as soon as I try to engage both R and D it suddenly turns off.
